CME Outbound calling groups
Greetings,
I have a CME system with different groups of extensions and phones.
Extensions 100-105 should use voice-port 0/0/0 - 0/0/3 for outbound calling
Extensions 200-205 should use voice-port 0/1/0 - 0/1/3 for outbound calling
and so on.
Inbound calling configurations I would hope would not be effected (like connection plar).
How do I accomplish this?
David
Hall of Fame Super Gold
Re: CME Outbound calling groups
It is not a trivial configuration, basically requires called number manipulation or COr list applied to ephone DN.
I do not have a compelte config example here, but would be able to provide consultancy if you are interested.
You can accomplish this by using the COR list, if you have not worked with cor-lists before then you would need to understand it first otherwise you will end up troubleshooting it for hours.
Example:
You will need to play with Inbound/Outbound assignment of cor lists: In this example here Phone 1 will use the dial-peer 100, phone 2 will use dial-peer 200 and phone 3 can use all of them.
dial-peer cor custom
name pt-portone
name pt-porttwo
name pt-portthree
dial-peer cor list css-portone
member pt-portone
dial-peer cor list css-porttwo
member pt-porttwo
dial-peer cor list css-portthree
member pt-portthree
dial-peer cor list css-phoneone
member pt-portone
dial-peer cor list css-phonetwo
member pt-porttwo
dial-peer cor list css-phonethree
member pt-portone
member pt-porttwo
member pt-portthree
dial-peer voice 100 pots
destination-pattern 9[2-9]..[2-9]......
corlist outgoing css-portone
port 0/0/1:23
dial-peer voice 200 pots
corlist outgoing css-porttwo
port 0/0/2:23
dial-peer voice 300 pots
corlist outgoing css-portthree
port 0/0/3:23
ephone-dn 1 dual-line
cor incoming css-phoneone
ephone-dn 2 dual-line
cor incoming css-phonetwo
ephone-dn 3 dual-line
cor incoming css-phonethree
Hope it helps.
Ovais.
You answered his question and my month long question.  I appreciate the post without the "consultancy" lol.
250
