Community Member
CME Parallel Blast Group and DNIS
Any help appreciated on this one
Running CME 8.0
I have a group of 15 sales staff which are members of a parallel hunt group which accepts inbound calls from 5 different DID numbers.
I need the staff to be able to identify the number the caller dialed using directory lookup.
DNIS lookup works if the hunt group is a ephone hunt-group but not if it's a voice hunt-group.
I need to use voice hunt-groups to enable parallel (Blast) funtionality. (Keeps the sales guys eager!!)
Is their anyway I could keep the blast funtionality and have the called number/directory name dispalyed?
I know I could overlay a DN but this may be a bit restrictive as they could have alot if inbound calls at one time and once they take a call could tie up that DN for a long time.
Paul
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CME Parallel Blast Group and DNIS
First of all, it would be probably better if you could use regualar ephone-hunt with login/logout softkey. I know that many customers really believe that racing for calls is the best, however I have disproved that in all cases and they had to agree with me afterwards. Beside, ephone-hunts, unlike voice hunts, supports statistics to tell management about each operator individual performance.
This being said, once you use voice hunts, you loose the native support for "service dnis dir-lookup", that is supported exclusively on SCCP phones. To keep this feature, one possiblity is using shared lines with octo-line DN.
Then for situations where the above is still not possible,  I've added a called number display feature to both my "B/ACD-AA" and "number 2 name" TCL/ICR scripts, that can be acquired at www.ciscoscripts.com
Green
You could try building a ephone type hunt group which refers to the blast type group.
Something like this.
8000 is target number, this links from the ephone huntgroup which
only has a member of the blast group 8888.
ephone-hunt 11 sequential
pilot 8000
list 8888
final 8888
voice hunt-group 44 parallel
pilot 8888
list 1001, 1002, 1003, 1004
final 2000
timeout 20
Alex
Regards, Alex. Please rate useful posts.
pilot 8000
list 8888
final 8888
pilot 8888
final 2000
timeout 20
Alex
I'm afraid that cannot be done.
Ephone-hunt list members can only be "normal ephone-dn" numbers and nothing else.
Community Member
Thanks Paolo,
You've confirmed what I suspected!
In relation to your TCL scripts, are you saying that the "Name 2 number" script will solve my problem regarding blast groups and DNIS?
I implemented the login/logout softkey a while ago and seemed to work well for the first few weeks.
The problem is that the staff have got lazy and the client wants the phones answered as quickly as possible without having to rely on staff to logout if not at their desks, I did try the auto-logout feature but then they never logged back in!! :-)
Paul
That is the exact description of most workplace situations that I've seen where they wanted blast rings.
They have an employee performance/attitude problem, but expect to solve it by adapting the system to poor practices - wrong in my book.
Yes as indicated above, both my scripts can display the called number as a string on any phone type.
Thank you for the nice rating and good luck!
690
