CME parallel huntgroup.
Hi, I've configured some DN's as below:
ephone-dn 11 dual-line
number 202 no-reg primary
label 202
description 202
name 202
ephone-dn 12 dual-line
number 203 no-reg primary
label 203
description 203
name 203
ephone-dn 13 dual-line
number 204 no-reg primary
label 204
description 204
name 204
ephone-dn 14 dual-line
number 205 no-reg primary
label 205
description 205
name 205
ephone-dn 15 dual-line
number 206 no-reg primary
label 206
description 206
name 206
They work great. Im trying to impliment the following parallel hunt group:
voice hunt-group 1 parallel
pilot 203
list 204, 205, 206
final 207
timeout 20
But i get this message:
UC520(config-voice-hunt-group)#list 203, 204
Number 203 is not a valid voice register dn. Re-enter 'list.'
Any ideas?
Cheers
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CME parallel huntgroup.
Hi, "voice hunt-group" is a command for SIP phones exclusively.
SCCP phones do not currently support parallel hunt-groups. Supposedly, they will in a future CME release.
You either use shared lines, or a TCL/IVR service that I wrote for the purpose:
http://pbevila.fastmail.fm/public/bcast.tcl
damn, I knew it was too good to be true.
Cheers!
Hi Paulo, im looking at your TCL script there. I can see that the first few lines are hashed out, and one line contains extension numbers in 'param destinations'
However I cant see param destination being called further down in the script, so does this mean they're not hashed out but just are variables?
cheers :)
Hi, hashed lines are comments and config examples.
Actual configuration is done with parameter commands under service.
OK, im looking to impliment this script towards the end of the week on our piece of kit to give it a good testing.
My first question is... how do I make the system use the TCL script :) Do you have any install guide or config guide as I havent used TCL scripts before :(
Is it as simple as ftp'ing this script onto my UC520 box and then all phones will ring together? Forgive my poor TCL knowlege :(
Copy the file to the box, and configure as per example in the files itself.
Ah im starting to get it now, so all I need to config on the box are :
application
service bcast flash:/IVR/bcast.tcl
param destinations 201,202,203 (or all the phones I want to ring)
# dial-peer voice 100 pots
# description broadcast hunt-group
# service bcast
# incoming called-number 5551234
Now Dial-peer voice 100 pots. Do I need this specific dial peer, or can I apply it to an exsiting dial peer? For example:
dial-peer voice 54 pots
description **Answers All Incoming Calls**
>>service bcast
>> incoming called-number .
direct-inward-dial
port 0/1/0
Thanks for your help mate, I very much appreciate it
Hi, under DP, you need service, incoming called-number, codec g711u and no vad. You don't need anything else.
Ok, ill be giving this a go tomorrow, fingers crossed :)
I stand corrected, of course codec and vad do not apply to a pots DP.
These would apply when you configure a voip "loopback" DP in order to be able to access the service from ip phones as well.
590
