Community Member
CME: Parked calls do not displayed on the IP Phone display [lost]
CME and CUE technolgies:
When calls are placed on park, the numbers of the line that the calls are placed on does not always show up on the phone display. How can I retrieve calls placed on park with out randomly hitting extension. Also, note this is an intermittent problem - typically happens a couple times a day.
Any ideas -
Hall of Fame Super Gold
Re: CME: Parked calls do not displayed on the IP Phone display [
Which exact IOS are you running ?
Community Member
Version 12.4(13r)T
c2800nm-ipvoicek9-mz.124-15.T3.bin
Community Member
Any ideas.. Anyone..
thx
Hi, 12.4(11)XJ4 has more bug fixes of what you're running, would be worth to give it a try.
Community Member
can you provide the release notes or links point to the bug fix? its gonna be hard justifing a IOS upgrade w/ support documentation.
Sorry, considering that there are certain bugs that never went into the relnotes as well, this one for sure hasn't so it's a bit of hit or miss. However XJ4 does what (15)T3 does, is stable and the test is painless. Good luck!
Community Member
Hi p.bevilacqua,
In a previous email thread, you suggested that I should change the code to 12(4)11 XJ4 - my current code is 12.4(13r)T - that would require a downgrade of code, right? -
just so i'm clear - is the XJ4 the most stable code b/c the (13r)T code shipped with the equipment [always, thought T train code was the most stable]..
p.bevilacqua
Yes, XJ4 is stable code and I would recommend you try with that IOS.
132
