CME-PBX Integration Problem
I have this strange problem I'm facing.
I have a single site on a Panasonic PBX and three remote site on Cisco CME.
I configured the remote sites with a voip dial-peer pointing to the PBX IP Address. I have a problem with a single site.
The problem can be broken down as follows:
IP Phone -> Analog = Ringing then the call disappears from the "voice call status" as the user picks up
Analog -> IP Phone = Ringing then as the IP Phone picks up, and I see "Connected" on my IP Phone but the "show voice call status" shows none in the codec column indicating that it's not picked up yet and all the while the the analog phone is hearing ringback and the IP Phone hears MOH tone !!!!!
I have changed the codecs repeatedly even from the PBX side but still no luck. I now have a voice class with all the codecs
There are firewalls at each site but I've set policies to allow H323 and RTP between them.
I'm sure I'm not hitting any bug or anything as one of the working remote sites have the exact IOS image and CME version.
In all cases I have hardware transcoders configured and they seem to be registered.
Router#sh sdspfarm units
mtp-1 Device:confdsp1 TCP socket:[-1]  UNREGISTERED
actual_stream:0 max_stream 0 IP:0.0.0.0  0  Unknown 0 keepalive 0
mtp-2 Device: TCP socket:[-1]  UNREGISTERED
mtp-3 Device:mtp001bd5ed6bf0 TCP socket:[1]  REGISTERED
actual_stream:8 max_stream 14 IP:10.10.21.102  44045  MTP Dixieland keepalive 22486
Supported codec: G711Ulaw
                 G711Alaw
                 G729
                 G729a
                 G729b
                 G729ab
                 GSM FR
max-mtps:5, max-streams:8, alloc-streams:8, act-streams:0
Excerpts of the configuration:
voice class codec 20
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
codec preference 4 g711alaw
dial-peer voice 6660 voip
description <<INCOMING DIAL-PEER>>
  paramspace callsetup after-hours-exempt TRUE
session target ipv4:10.10.21.102
incoming called-number [789]..
dial-peer voice 6665 voip
description <<VOIP CONNECTION TO REMOTE SITE>>
destination-pattern 6[123]..
voice-class codec 20
session target ipv4:10.10.2.101
sccp local GigabitEthernet0/0
sccp ccm 10.10.21.102 identifier 1 version 4.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 2 register mtp001bd5ed6bf0
associate profile 1 register confdsp1
switchback method graceful
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729br8
codec g729r8
maximum sessions 7
associate application SCCP
telephony-service
ip source-address 10.10.21.102 port 2000
sdspfarm units 5
sdspfarm transcode sessions 4
sdspfarm unregister force
sdspfarm tag 1 confdsp1
sdspfarm tag 2 mtp001bd5ed6bf0
Any ideas?
Ahmed
1 REPLY
Bronze
Re: CME-PBX Integration Problem
It does sound like you are hitting a codec issue from what you describe , can you just confirm that it only fails on one of the sites and that the other two work.
If the others work can you tell me what codec gets negotiated.
Cheers
Mark
465
