CME Phone Issue
I am trying to add a new 7921 onto the CME box. The phone is authenticated on the wireless, the only problem is that I can't seem to get the phone to register with CME.
When I add the ephone's MAC address, I will see the below logs from TFTP. I have confirmed that correct MAC address of the phone. It is ephone 6.
Jan 29 16:52:07 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:52:07 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:11 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:15 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:19 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:23 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:27 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:07 CST: TFTP: Looking for WLAN0021.A024.4B35.xml
Jan 29 16:53:53 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:53:57 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:54:01 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:54:05 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:54:09 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:54:13 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
<br /><br /><br /><br />
Re: CME Phone Issue
Attached is my config
Re: CME Phone Issue
Something simple to try.. Have you tried a factory reset of the phone? If not, here are the steps..
Arrow Down to Settings
Select Phone Settings or press 1
Press **2
Quickly press Yes to confirm (left soft key)
Re: CME Phone Issue
Still getting the same message after reset.
Feb 2 09:38:34 CST: TFTP: Server request for port 1024, socket_id 0x489A3B7C fo
r process 250
Feb 2 09:38:34 CST: TFTP: read request from host 192.168.7.101(1024) via FastEt
hernet0/0.1
Feb 2 09:38:34 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Feb 2 09:38:34 CST: TFTP: Sending error 1 No such file
Feb 2 09:38:35 CST: TFTP: Server request for port 1024, socket_id 0x496F1DBC fo
r process 250
Feb 2 09:38:35 CST: TFTP: read request from host 192.168.7.101(1024) via FastEt
hernet0/0.1
Feb 2 09:38:35 CST: TFTP: Looking for WLAN0021A0244B35.xml
Feb 2 09:38:35 CST: TFTP: Sending error 1 No such file
Feb 2 09:38:39 CST: TFTP: Server request for port 1024, socket_id 0x489A3B7C fo
r process 250
Feb 2 09:38:39 CST: TFTP: read request from host 192.168.7.101(1024) via FastEt
hernet0/0.1
Feb 2 09:38:39 CST: TFTP: Looking for WLAN0021A0244B35.xml
Feb 2 09:38:39 CST: TFTP: Sending error 1 No such file
Feb 2 09:38:43 CST: TFTP: Server request for port 1024, socket_id 0x496F1DBC fo
r process 250
Feb 2 09:38:43 CST: TFTP: read request from host 192.168.7.101(1024) via FastEt
hernet0/0.1
Feb 2 09:38:43 CST: TFTP: Looking for WLAN0021A0244B35.xml
Feb 2 09:38:43 CST: TFTP: Sending error 1 No such file
All possible debugging has been turned off
Feb 2 09:38:48 CST: TFTP: Server request for port 1024, socket_id 0x489A3B7C fo
r process 250
Feb 2 09:38:48 CST: TFTP: read request from host 192.168.7.101(1024) via FastEt
hernet0/0.1
Feb 2 09:38:48 CST: TFTP: Looking for WLAN0021A0244B35.xml
Feb 2 09:38:48 CST: TFTP: Sending error 1 No such file
Thanks for the reply though
Re: CME Phone Issue
Under telephony-services try this:
config t
telephony-service
create cnf-files
Then try to register phone again.
Hope that helped, if so please rate.
Re: CME Phone Issue
Was this phone working before and you upgraded the firmware and now its not. If it never worked before, is the phone getting the correct IP information? TFTP, Gateway etc....
Re: CME Phone Issue
The original phone was a 7921, it broke and so we got a new one. It has the same info as the old one as far as TFTP, IP addressing and gateways go.
Re: CME Phone Issue
thanks for the response but I tried this earlier, just did not post it.
Hall of Fame Super Gold
Re: CME Phone Issue
Which IOS are you using ? I'm seeing strange TFTP trouble with 12.4(20)T1
Re: CME Phone Issue
12.4(15)T5
183
