Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CME Phones out bound calling fails to remote CME PRI
We have two CME's.  One has phones registered to it and the other has a PRI with backup POTS lines.  Inbound calls from the PRI to the phones work fine.  But when a phone on the CME tries to place a call across the PRI on the remote CME the call fails and ends up going out the backup POTS lines.  If I register a phone to the CME that has the PRI then the outbound call across the PRI works.  I will list a debug for a failed call.  Any help is appreciated.
   cc_api_call_setup_ind_common:
   cisco-username=10.255.101.106
   ----- ccCallInfo IE subfields -----
   cisco-ani=33136
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9826087000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
May 29 14:36:53.250 CAT: //-1/C6AD63E6B95F/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x490E7B00, Call Info(
   Calling Number=33136,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not       Screened, Presentation=Allowed),
   Called Number=9826087000(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=T      RUE,
   Incoming Dial-peer=3005, Progress Indication=ORIGINATING SIDE IS NON ISDN(3),       Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS      E), Call Id=1110
May 29 14:36:53.250 CAT: //-1/C6AD63E6B95F/CCAPI/ccCheckClipClir:
   In: Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pr      esentation=Allowed)
   Out: Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screened, P      resentation=Allowed)
May 29 14:36:53.254 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 29 14:36:53.254 CAT: :cc_get_feature_vsa malloc success
May 29 14:36:53.254 CAT:  cc_get_feature_vsa count is 1
May 29 14:36:53.254 CAT: :FEATURE_VSA attributes are: feature_name:0,feature_tim      e:1282183512,feature_id:1115
May 29 14:36:53.254 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screen      ed, Presentation=Allowed),
   Called Number=9826087000(TON=Unknown, NPI=Unknown))
May 29 14:36:53.254 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
May 29 14:36:53.254 CAT: :Inside cc_build_feature_vsa
May 29 14:36:53.254 CAT:  feature call basic
May 29 14:36:53.254 CAT: cc_build_feature_vsa attr is fn:TWC,ft:05/29/2012 14:36      :53.254,cgn:33136,cdn:9826087000,frs:0,fid:1115,fcid:C6AD63E6A8C111E1B95FC279C57      3494C,legID:456
May 29 14:36:53.258 CAT: //1110/C6AD63E6B95F/CCAPI/cc_process_call_setup_ind:
   Event=0x49CE5578
May 29 14:36:53.258 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 9826087000
May 29 14:36:53.258 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetContext:
   Context=0x4C5329F8
   >>>>CCAPI handed cid 1110 with tag 3005 to app "_ManagedAppProcess_Default"
May 29 14:36:53.258 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=107, Params=0x4C53E898, Progress Indication=ORIGINATING SI      DE IS NON ISDN(3)
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccCheckClipClir:
   In: Calling Number=27225100(TON=Unknown, NPI=Unknown, Screening=Not Screened,       Presentation=Allowed)
   Out: Calling Number=27225100(TON=Unknown, NPI=Unknown, Screening=Not Screened      , Presentation=Allowed)
   Destination Pattern=9T, Called Number=9826087000, Digit Strip=TRUE
   Calling Number=27225100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pre      sentation=Allowed),
   Redirect Number=, Display Info=Nugier, Billy
   Account Number=10.255.101.106, Final Destination Flag=TRUE,
   Guid=C6AD63E6-A8C1-11E1-B95F-C279C573494C, Outgoing Dial-peer=107
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=27225100
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9826087000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4A5C8644, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=27225100,(Calling Name=Nugier, Billy)(TON=Unknown,       NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=9826087000(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10      7, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl      ication Call Id=)
May 29 14:36:53.262 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 29 14:36:53.262 CAT: :cc_get_feature_vsa malloc success
May 29 14:36:53.262 CAT:  cc_get_feature_vsa count is 2
May 29 14:36:53.262 CAT: :FEATURE_VSA attributes are: feature_name:0,feature_tim      e:1282183288,feature_id:1116
May 29 14:36:53.262 CAT: //1111/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
May 29 14:36:53.262 CAT: //1111/C6AD63E6B95F/CCAPI/ccCallSetContext:
   Context=0x4C53E848
May 29 14:36:53.262 CAT: //1110/C6AD63E6B95F/CCAPI/ccSaveDialpeerTag:
May 29 14:36:53.266 CAT: ISDN Se0/1/1:15 Q931: Applying typeplan for sw-type 0x1      2 is 0x0 0x0, Calling num 27225100
May 29 14:36:53.270 CAT: ISDN Se0/1/1:15 Q931: Sending SETUP  callref = 0x0127 c      allID = 0x80A8 switch = primary-net5 interface = User
May 29 14:36:53.270 CAT: ISDN Se0/1/1:15 Q931: TX -> SETUP pd = 8  callref = 0x0      127
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x80, '27225100'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '826087000'
May 29 14:36:53.426 CAT: ISDN Se0/1/1:15 Q931: RX <- CALL_PROC pd = 8  callref =       0x8127
May 29 14:36:53.430 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
May 29 14:36:53.430 CAT: :Inside cc_build_feature_vsa
May 29 14:36:53.430 CAT:  feature call basic
May 29 14:36:53.430 CAT: cc_build_feature_vsa attr is fn:TWC,ft:05/29/2012 14:36      :53.262,cgn:27225100,cdn:9826087000,frs:0,fid:1116,fcid:C6AD63E6A8C111E1B95FC279      C573494C,legID:457
May 29 14:36:53.430 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_proceeding:
   Interface=0x4A5C8644, Progress Indication=NULL(0)
May 29 14:36:53.706 CAT: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref       = 0x8127
        Cause i = 0x829F - Normal, unspecified
        Progress Ind i = 0x8288 - In-band info or appropriate now available
May 29 14:36:53.706 CAT: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconn      ect; Postpone sending RELEASE for callid 0x80A8
May 29 14:36:53.706 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=31, Progress Indication=INBAND(8), Interface=0x4A5C8644
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disc_prog_ind:
   Event(Progress Indication=0x0), Call Entry(Responsed=TRUE)
May 29 14:36:53.710 CAT: //1110/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=1111
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/ccCallDisconnect:
   Cause Value=31, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C      ause=31)
   Cause Value=31, Call Entry(Responsed=TRUE, Cause Value=31)
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
May 29 14:36:53.710 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disc_cause_update      :
   Cause Value=31
   Call Entry(Disconnect Cause=31)
May 29 14:36:53.714 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A5C8644, Tag=0x0, Call Id=1111,
   Call Entry(Disconnect Cause=31, Voice Class Cause Code=0, Retry Count=0)
May 29 14:36:53.718 CAT: //1111/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
May 29 14:36:53.718 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 29 14:36:53.718 CAT: :cc_free_feature_vsa freeing 4C6C9070
May 29 14:36:53.718 CAT:  vsacount in free is 1
May 29 14:36:53.718 CAT: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0      x0127
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=108, Params=0x4C536360, Progress Indication=ORIGINATING SI      DE IS NON ISDN(3)
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/cc_fill_tg_params:
   Not a cic call
   Trunk Group Select Interface Success;
   Interface=0x49D2F938, Selected Interface=1, Selected DSL=-1
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/ccCheckClipClir:
   Calling Number=33136(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presen      tation=Allowed),
   Guid=C6AD63E6-A8C1-11E1-B95F-C279C573494C, Outgoing Dial-peer=108
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=33136
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9826087000
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
May 29 14:36:53.722 CAT: //1110/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x49D2F938, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=33136,(Calling Name=Nugier, Billy)(TON=Unknown, NP      I=Unknown, Screening=Not Screened, Presentation=Allowed),
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10      8, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=FXO, tg_label_flag=2, A      pplication Call Id=)
May 29 14:36:53.722 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 29 14:36:53.722 CAT: :cc_get_feature_vsa malloc success
May 29 14:36:53.722 CAT:  cc_get_feature_vsa count is 2
May 29 14:36:53.722 CAT: :FEATURE_VSA attributes are: feature_name:0,feature_tim      e:1282183288,feature_id:1117
May 29 14:36:53.726 CAT: //1112/C6AD63E6B95F/CCAPI/ccIFCallSetupRequestPrivate:
May 29 14:36:53.726 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallSetupRequest:
   Trunk Group Call Setting;
   Call Entry(Retry Count=0, Voice Class Cause Code=0)
May 29 14:36:53.726 CAT: //1112/C6AD63E6B95F/CCAPI/ccCallSetContext:
   Context=0x4C536310
May 29 14:36:53.726 CAT: //1110/C6AD63E6B95F/CCAPI/ccSaveDialpeerTag:
May 29 14:36:53.726 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_modify_tgt_cid_call_ac      tive_record:
   Target Trkgrp Route Label=FXO, tg_label_flag=TRUE, Call Id=0x456
May 29 14:36:53.730 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
May 29 14:36:53.730 CAT: :Inside cc_build_feature_vsa
May 29 14:36:53.730 CAT:  feature call basic
May 29 14:36:53.730 CAT: cc_build_feature_vsa attr is fn:TWC,ft:05/29/2012 14:36      :53.722,cgn:33136,cdn:9826087000,frs:0,fid:1117,fcid:C6AD63E6A8C111E1B95FC279C57      3494C,legID:458
May 29 14:36:53.730 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_proceeding:
   Interface=0x49D2F938, Progress Indication=NULL(0)
May 29 14:36:53.746 CAT: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callre      f = 0x8127
May 29 14:36:57.166 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_cut_progress:
   Interface=0x49D2F938, Progress Indication=INBAND(8), Signal Indication=INTERC      EPT(2),
   Cause Value=0
May 29 14:36:57.166 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
May 29 14:36:57.166 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_called_ccm_detecte      d:
   CallInfo(ccm detected=0)
May 29 14:36:57.166 CAT: //1110/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4C6304FC, callID1=0x456, callID2=0x458, tag=0x0)
   (confID=0x4C6304FC, callID1=0x456, gcid=0-0-0-0, tag=0x0)
May 29 14:36:57.166 CAT: //1112/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4C6304FC, callID2=0x458, gcid=0-0-0-0, tag=0x0)
May 29 14:36:57.166 CAT: //1110/C6AD63E6B95F/CCAPI/ccConferenceCreate:
   Conference Id=0x4C6304FC, Call Id1=1110, Call Id2=1112, Tag=0x0
May 29 14:36:57.166 CAT: //1110/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May 29 14:36:57.166 CAT: cc_api_get_xcode_stream : 4534
May 29 14:36:57.166 CAT: //1110/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0xDE, Source Interface=0x490E7B00, Source Call Id=1110,
   Destination Call Id=1112, Disposition=0x0, Tag=0x0
May 29 14:36:57.170 CAT: //1112/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0xDE, Source Interface=0x49D2F938, Source Call Id=1112,
   Destination Call Id=1110, Disposition=0x0, Tag=0xFFFFFFFF
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/cc_generic_bridge_done:
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xDE, Destination Call Id=1112)
May 29 14:36:57.170 CAT: //1112/C6AD63E6B95F/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xDE, Destination Call Id=1110)
May 29 14:36:57.170 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_caps_ind:
   Destination Interface=0x490E7B00, Destination Call Id=1110, Source Call Id=11      12,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_caps_ind:
   Destination Interface=0x49D2F938, Destination Call Id=1112, Source Call Id=11      10,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
May 29 14:36:57.170 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9610)
May 29 14:36:57.170 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_caps_ack:
May 29 14:36:57.174 CAT: //1110/C6AD63E6B95F/CCAPI/cc_process_notify_bridge_done      :
   Conference Id=0xDE, Call Id1=1110, Call Id2=1112
May 29 14:36:57.174 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_voice_mode_event:
   Call Id=1112
   Call Entry(Context=0x4C536310)
May 29 14:36:57.174 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_connected:
   Interface=0x49D2F938, Data Bitmask=0x1, Progress Indication=DESTINATION IS NO      N ISDN(2),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
May 29 14:36:57.178 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=1110
May 29 14:36:57.178 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_called_ccm_detecte      d:
May 29 14:36:57.178 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallConnect:
   Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
May 29 14:36:57.182 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_called_ccm_detecte      d:
May 29 14:36:57.182 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
May 29 14:36:57.182 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallNotify:
May 29 14:36:58.498 CAT: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.50.18.123:1645,      1813 is not responding.
May 29 14:36:58.498 CAT: %RADIUS-4-RADIUS_ALIVE: RADIUS server 10.50.18.123:1645      ,1813 is being marked alive.
May 29 14:37:01.838 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x490E7B00, Call Id=1110
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
May 29 14:37:01.838 CAT: //1110/C6AD63E6B95F/CCAPI/ccConferenceDestroy:
   Conference Id=0xDE, Tag=0x0
May 29 14:37:01.838 CAT: //1110/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
May 29 14:37:01.838 CAT: //1112/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=1110, Disposition=0x0, Tag=0x0
May 29 14:37:01.838 CAT: //1110/C6AD63E6B95F/CCAPI/cc_generic_bridge_done:
May 29 14:37:01.842 CAT: //1110/C6AD63E6B95F/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C      ause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
May 29 14:37:01.842 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
May 29 14:37:01.842 CAT: //1112/C6AD63E6B95F/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C      ause=0)
May 29 14:37:01.842 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
May 29 14:37:01.846 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_get_transfer_info:
May 29 14:37:01.850 CAT: //1110/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x490E7B00, Tag=0x0, Call Id=1110,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
May 29 14:37:01.850 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 29 14:37:01.850 CAT: :cc_free_feature_vsa freeing 4C6C9150
May 29 14:37:01.850 CAT:  vsacount in free is 1
May 29 14:37:01.862 CAT: //1112/C6AD63E6B95F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49D2F938, Tag=0x0, Call Id=1112,
   tg for this call is FXO success/fail is 1
May 29 14:37:01.862 CAT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
May 29 14:37:01.862 CAT: :cc_free_feature_vsa freeing 4C6C9070
May 29 14:37:01.862 CAT:  vsacount in free is 0un all
All possible debugging has been turned off
PEMrt1#
Everyone's tags (7)
1 ACCEPTED SOLUTION
VIP Super Bronze
Pls rate all useful posts!
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Here are the cme dial-peer configs
CME (PEMrt4) with Phones
dial-peer voice 208 voip
description "Dial Peer for PRI Access"
preference 1
destination-pattern T
session target ipv4:10.101.85.1
voice-class codec 1
CME (PEMrt1) with PRI
dial-peer voice 3005 voip
description Dial-Peer to PEMrt4
destination-pattern 331[0-4].
session target ipv4:10.255.101.106
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 3006 voip
destination-pattern 332..
codec g711ulaw
dial-peer voice 107 pots
translation-profile outgoing TranslateOutgoingMain
preference 1
destination-pattern 9T
port 0/1/1:15
dial-peer voice 101 pots
translation-profile incoming TranslateIncoming
incoming called-number .
direct-inward-dial
VIP Super Bronze
The call is matching dial-peer 10 and 107 on router 1...What is in thos dial-peers?
Re: CME Phones out bound calling fails to remote CME PRI
I don’t have a dial-peer 10 configured. Here are all the dial-peers I have configured at this time on that router.
dial-peer voice 3000 voip
description Dial-Peer to Maputo
destination-pattern 331[5-9].
session target ipv4:10.101.254.1
direct-inward-dial
dial-peer voice 208 pots
preference 1
destination-pattern 8T
port 0/1/1:15
preference 1
port 0/1/1:15
dial-peer voice 999030 pots
destination-pattern 33199
port 0/3/0
codec g711ulaw
codec g711ulaw
dial-peer voice 108 pots
trunkgroup FXO
preference 2
dial-peer voice 207 pots
trunkgroup FXO
description "FXO Backup Dial-Peer for PSTN Access"
preference 2
Oh, that is not dial-peer 10, that is a space in the copy and paste I did. It is 107.
VIP Super Bronze
Can you send a sh run of both routers? Which router did you take this log from?
I took the debug from the CME with the PRI.  I will send you a message with the sh run of each router.
VIP Super Bronze
Ok,
Billy this is what is going on..
The call goes out first through dial-peer 107 which is your PRI port, it goes to the PSTN and the telco disconnects the call
Then it comes back and tries the second dial-peer 108 and it connects..
So you need to talk to your provider and find out why they are disconeecting the call
Ok, thanks.
VIP Super Bronze
Ok, when this issue is resolved I will. Thanks.
1179
