CME picking random FXO ports ???
Dear All,
I am using CME router 3825. I have one FXO card (4 ports) and four PSTN lines are connected to my router. I have one 7921 wireless ip phone and three 7911 ip phones.
I want all the four users to use their own FXO port assigned to them.
I have attached the running configuration of my router.
I have configured my router in such a way that I want every user to use their own FXO port for making incoming and outgoing calls. But still the router is picking random FXO ports. How can I restrict user to user their own FXO port for making incoming and outgoing calls. Any other suggestion or tip will be very helpful to me.
Following are the four PSTN numbers which i have assigned to FXO ports:
voice-port 0/1/0 = 8579210
voice-port 0/1/1 = 8573083
voice-port 0/1/2 = 8572138
voice-port 0/1/3 = 8579206
Your consideration in this regard will highly be commendable.
Thanks & Regards,
Malik.
2 ACCEPTED SOLUTIONS
Re: CME picking random FXO ports ???
There are a number of ways you can accomplish this, either using corlists, or configuring your ephone-dn's as private lines. Here is an example of the private line configuration.
dial-peer voice 3333 pots
corlist outgoing CALL-8579210
answer-address 8579210
destination-pattern 80
port 0/1/0
ephone-dn 1 dual-line
number 8579210
corlist incoming CALL-8579210
trunk 80
8579210 calls 5551212. 5551212 will automatically have 80 prepended to it and match dial-peer 3333. The dial-peer will strip the 80 and forward the rest of the digits out of the fxo port 0/1/0.
Hope that made some sense. If so please rate.
alternatively you could try combination of answer address/translation profile. See here for more example:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Gurmakh
Hall of Fame Super Gold
Hi, your cor-based configuration appears to be correct, but one would need to troubleshoot with "debug voip dialpeer" to see what's really happening.
My reccomendation however is that you use the "advance key system" setting that does what you want:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html#wp1036976
port 0/1/0
number 8579210
trunk 80
Hi Kennet,
The trunk suggestion is good, in fact I was recommending the same.
I wanted to make an observation about your example. If you add the trunk keyword to the user DN, the trunk digits are added to any call made from that DN, consequently user cannot call the other DNs! So in the cisco example, DNs with trunk are additional and dedicated to the FXO lines. This way each user will have two DNs, one for receiving calls and make internal calls, the other for external calls.
Hi Paolo,
I was actually thinking about that and it dawned on me after it was too late to edit the post. LOL
hehe.. not wanting to seem patronizing but I've rated your post as you're one of the best here.
Dear Mr. Kenneth,
Thanks for your reply. I really appriciate for your support. You are right with this configuration it will work. I already test it but the thing is that
i have cisco wireless phone 7921. It works fine with this configuration shown below like it can make and receive calls:-
voice-port 0/1/0
connection plar 8579210
dial-peer voice 1 pots
destination-pattern .T
port 0/1/0
number 8579210
ephone 1
mac-address 0021.55D5.E280
type 7921
button 1:1
But when i switch my configuration to this shown below:
voice-port 0/1/0
answer-address 5775477
destination-pattern A1
port 0/1/0
number 5775477
trunk A1
ephone 1
type 7921
button 1:1
then the wireless phone 7921 only receives calls but not able to make outgoing calls. Any idea or hint will highly commendable. The problem is that i cannot assign .T dial-peer because with this router will pick random FXO ports.
7911 works fine with trunk access A1, A2 so on. But wireless ip phones 7921 don't make outing going calls with trunk access A1 they receive only. Also I have tested with different access trunks like 80 or 90 but the problem remains the same.
Any body can help me in this issue. I will be very great full. My main goal is that I want all 7911 and 7921 to use their own FXO ports for making incoming and outgoing calls.
Malik.
Dear Mr. Kenneth,
voice-port 0/1/0
port 0/1/0
number 8579210
ephone 1
type 7921
button 1:1
voice-port 0/1/0
port 0/1/0
number 5775477
trunk A1
ephone 1
type 7921
button 1:1
Malik.
Gurmakh
Dear Mr. Gurmakh,
Thanks for your help. Your link works too. Thanks a lot.
Malik.
Hi Malik,
Your very welcome. Glad to be of help.
Gurmakh
Dear Mr. Gurmakh,
I am really very happy. I really appreciate for your help and support. I have configured my router according to the configuration given in cisco doc link send by you.
With this config. i have to add digits like 19 or 29 or 39 before dialing any number for make router pick assigned FXO ports.
Is there anyother way i can make outgoing calls without dialing the digits 19 or 29 keeping in mind that the router should pick assgined FXO ports not random ports.
Thanks & Regards,
Malik.
Hi Malik,
Before dialling any external number you dial 9 (which is typically used in many countries for an outside line) then the rest of the digits. You do not need to dial 19 or 29 or 39.
For example, if you dial 9 followed by the external number from 'phone 1' the 9 will get translated to '19' which will match one of the pots dial peers. The pots configuration will force the call to route out of a specific voice port (0/1/0)
Hi Malik,
As some of the other guys have mentioned there are a few options:
1) Trunk configuration
2) Corlist restriction
3) Translation pattern on the ephone-dn
Restrictions
1) All calls go through the FXO and you can't reach other DNs like Paolo mentioned.
2) This should work fine. I'm not a big fan of corlists as they can be confusing and hard to manage
3) Configuration takes some thinking, may be hard to implement if you have a complicated dial plan. It may be easier to understand and troubleshoot, depending on how you see it.
I was thinking of something like this:
port 0/0/0
destination-pattern #1.T
connection plar 200
ephone-dn 1
translation-profile incoming Port1
number 200
translation-rule 1
rule 1 /^\(...\)$/ /\1/ ! these are your 3 digit internal extensions
rule 2 /^\(.*\)/ /#1\1/ ! this prepends 1# to all calls that aren't 3 digit extensions
translation-profile Port1
translate called 1
hth,
nick
Dear Mr. Nick
I have implemented Cisco Call Manager v6 with voice gateway 3845.
The problem which i m facing is that when somebody from outside calls our PSTN number (analog number) following are the issues which we face:
1.Sometimes the auto attendant picks the call and sometimes it does not.
2.Sometimes when the PSTN number is dialed the call is attended but there is no repsone from the auto attendant.
Any of your suggestions will be highly commendable. What can we be the possible suggestion to solve this issue.
I am in deep trouble as all of our customers are calling on that PSTN number.
kindly find attached config of cme and cue with show run and show ver commands output.
The gateway configuration and CUE configuration isn't very helpful because this is all MGCP controlled.
I would suggest opening a TAC case so you can pull traces and find out what's going on.
-nick
Dear Mr. Nick,
Thanks for your reply. Is there any other troubleshooting tips before i open a TAC case. I will be very thankful to you.
Awaiting for your reply.
Malik.
Hi Malik,
I would do some test calls and track them with 'show voice call summary' and look at exactly which port you're coming in. If you can figure out how to recreate the problem, it can be solved many times faster. Right now, the problem description isn't very clear and it's very muddy to troubleshoot.
-nick
do you need any kind of output of show commands from my side. i will be very greatful to u if u help me to sort out this issue.
Unfortunately the outputs are too large for something to look at on a web forum.
I would work on figuring out exactly what the problem is, and if you can create a more clear problem statement, we will be able to better help you.
-nick
A clear problem statement would be like this:
CUE - cue auto attendant script intermittently working.
Like for example when somebody dials the PSTN number the AA sometimes picks the call and sometimes it does not picks the call (its keeps ringing)
Second thing is that sometimes the if you call the PSTN number, the called is picked up but there is no response from the AA.
Unfortunately even for a problem such as that, you will need to run a lot of debugs for a large amount of time (since you can't easily reproduce the problem)
That would be best handled by TAC.
It should be noted that if you have a custom script on the AA, and it's CUE, then TAC will not help you support the script. They will make sure that the call is getting handed off correctly, and after that the burden is on the writer of the script.
-nick
On the 3845, try entering the following
config t
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
Hope that helped, if so please rate.
Dear Mr Kenneth,
thanks for the reply...i will add these commands and will let you know about the result..thanks for your suggestion.
regards,
Malik
Dear Mr Kenneth,
I added the above mentioned commands. But still no luck. Any other suggestion will highly be commendable.
Malik.
it sounds from ur AA secripts if you have aCRS try to debug it and see if it has problem with the answer step or what ever after it
thanks
647
