CME- Pickup group issue
Issue:- extension 684 (DEF) cannot pickup call from his colleagues with extensions:
673
672
Please enable this function for his extension that he is able to pickup call from extensions: 673 and 672
Step 1:- Check pickup group for telephony numbers 673 and 672 and
CME-R-1#show ephone telephone-number 673
DP tag: 0, primary
Tag 30, Normal or Intercom dn
  ephone 30, mac-address xxxx.xxxx.xxxx <- MAC Address, line 1
CME-R-1#
CME-R-1#sho
CME-R-1#show run
CME-R-1#show running-config | sec ephone  30
ephone  30
device-security-mode none
ephone-template 1
type 7911
button  1:30
CME-R-1#show running-config | sec ephone-dn  30
ephone-dn  30  dual-line
number 673
pickup-group 8<-------- Check  <-------- Check  <-------- Check
label ABC-673
description 111111121673
name ABC
corlist incoming JLR-unrestrictedCSS
corlist outgoing PhonesP
ephone-dn-template 1
CME-R-1#show ephone telephone-number 672
DP tag: 0, primary
Tag 22, Normal or Intercom dn
  ephone 22, mac-address xxxx.xxxx.xxxx <- MAC Address, line 1
CME-R-1#show running-config | sec ephone  22
ephone  22
ephone-template 1
type 7911
button  1:22
CME-R-1#show running-config | sec ephone-dn  22
ephone-dn  22  dual-line
number 672
pickup-group 8  <-------- Check  <-------- Check  <-------- Check
label BCD-672
description 111111121672
name Rainer  BCD
CME-R-1#show ephone telephone-number 684
DP tag: 0, primary
Tag 117, Normal or Intercom dn
  ephone 117, mac-address xxxx.xxxx.xxxx <- MAC Address, line 1
CME-R-1#show running-config | sec ephone  117
ephone  117
ephone-template 1
type 7911
button  1:117
CME-R-1#show running-config | sec ephone-dn  117 <-------- Check ephone-dn not configured with pickup group
ephone-dn  117  dual-line
number 684
label DEF
description 111111118684
name DEF
Step 2:- Add same pickup group to telephony number 684
CME-R-1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
CME-R-1(config)#ephone-dn  117
CME-R-1(config-ephone-dn)# pickup-group 8<-------- Check  <-------- Check  <-------- Check
ex
CME-R-1#conf t
CME-R-1(config)#ephone  117
CME-R-1(config-ephone)#reset
resetting xxxx.xxxx.xxxx <- MAC Address
CME-R-1#
1 REPLY
Hi.
Did you check this link?
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1092675
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
929
