CME Presence with Extension Mobility
I have a CME 8.6 running on a 2811 ISR.
It is currently configured with Extension Mobility. Phones are all 7960.
I want to implement presence and have followed the admin guide to do so, but I've come across a problem
blf-speed-dial command.
When trying to do this under ephone<tag> it says
"Please configure under logout profile for em enabled phone"
How does this work when it's configured for the logout profile and not the user profile?
I did try and configure it under there and it does not do anything.
btw I only have 1 logout profile for the entire system.
Felix
Everyone's tags (4)
1 ACCEPTED SOLUTION
Blue
The BLF is to be configured in Logout profile only. See below link and see section "Configuring a Logout Profile for an IP Phone"
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemobl.html
Command is
speed-dial speed-tag number [label label] [blf]
Ronak patel
Please rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
Command is
Ronak patel
Re: CME Presence with Extension Mobility
Hi Ron,
So in CME the phone appearance is a combination of
1) the voice user-profile
AND
2) logout profile
Which means I should have a unique logout profile for each user who is on EM and wants BLF?
Felix
Just to add that this is now working.
When you configure the BLF under the logout profile it "adds" it in the voice user-profile.
you can see the change when doing a show run, that the blf speed dial commands now appear under the user-profile.
Felix
766
