You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
CME question about a greeting
Hi Guys,
My question is:
Is possible to have a greeting only(no mail box) when nobody can answer inbound calls in CME Unity express?
thanks
  • IP Telephony
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Juancarlos,
Check;
Configuring an Announcement-Only Mailbox
Beginning in version 7.1, you can configure announcement-only mailboxes.  These mailboxes can play the user greeting and disconnect the call  only; they cannot take any messages from callers or send messages.
Announcement-only mailboxes enable you to:
Perform any operations that can be performed on a greeting in personal mailboxes, such as recording or deleting.
Use all the new greeting types introduced by the multiple greeting feature. For more information, see the Configuring Multiple Greetings.
Configure a General Delivery Mailbox as an announcement-only mailbox.
Also, announcement-only mailboxes:
Cannot be part of everyone's list (9999)
Are counted against the mailbox license
Have a default size of 5 minutes when they are created, but the default size can be modified later
Because announcement-only mailboxes cannot send or receive messages, you cannot:
Create distribution lists for them
Configure notification devices for them
Therefore announcement-only mailboxes cannot:
Have messages addressed to them
Have notifications cascaded to them
Receive broadcast messages
Subscribers can log in to announcement-only mailboxes using either the  TUI, VVE, or IMAP. However, there is no reason to use IMAP to log into  announcement-only mailboxes because they do not contain messages.
The following features are available only for personal mailboxes and cannot be used with announcement-only mailboxes:
Message expiration time
Message size
Fax configuration
The following operations are available only for personal mailboxes in  the TUI and VVE and cannot be used with announcement-only mailboxes:
Playing new, saved, or deleted messages
Sending messages
Setting message parameters, such as configuration lists or notification devices
SUMMARY STEPS
1. configure terminal
2. voice mailbox owner name type announcement-only [size seconds]
3. end
4. show voicemail detail mailbox name
DETAILED STEPS
Command or Action
Purpose
Step 1
configure terminal
Example:
se-10-0-0-0# configure terminal
Enters configuration mode.
Step 2
[size seconds]
se-10-0-0-0(config)# voice mailbox owner user-8 type  announcement-only size 60
Creates a mailbox that cannot be used to leave messages. It can only be used to make announcements.
Step 3
end
Example:
se-10-0-0-0(config)# end
Exits to privileged EXEC mode.
Step 4
Example:
se-10-0-0-0# show voicemail detail mailbox user-8
(Optional) Displays information about a mailbox.
Examples
The following is sample output from the show voicemail detail mailbox command:
e-10-0-0-0# show voicemail detail mailbox User-8
Owner:                                       /sw/local/users/User-8
Type:                                        Announcement Only
Description:                                 User1 mailbox
Busy state:                                  idle
Enabled:                                     true
Allow login without pin:          no
Mailbox Size (seconds):          300
Play Tutorial:                    false
Space Used (seconds):          17
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/administrator/AA_and_VM/guide/vmconfig.html#wpxref15407
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Hi Juancarlos,
Check;
Message size
Fax configuration
Sending messages
SUMMARY STEPS
3. end
DETAILED STEPS
Command or Action
Purpose
Step 1
configure terminal
Example:
Step 2
[size seconds]
Step 3
end
Example:
Step 4
Example:
Examples
Busy state:                                  idle
Enabled:                                     true
Cheers!
Rob
- OneRepublic
Thanks So much  for enlight me!!!!!
Hi Juan Carlos,
Great info from Rob (+5 to you). Besides using announcement-only mailbox, you can use Unity Express scripts to play prompts and then disconnect the call or doing something else like a transfer to a hunt group pilot, for example. So if you are familiar by creating those scripts then you have another option there.
Gabriel.
Hi JC,
You are most welcome my friend!
Gabriel....nice thinking on the "scripting" angle +5
Cheers!
Rob
- OneRepublic
189
