CME Question automatic calling
Anyone know if it is possible to setup automatic calling with call manager express?
for example, extension 300 with a user id of user1 lifts there handset and the phone automatically calls extension 301 without any intervention?
Cheers
Chris
Bronze
Re: CME Question automatic calling
enable the connection plar (private line automated ringer) command under the voice port.
thanks for the response.
but this is an ip phone not an anaologue.
Only 8 of the ip phones will need this feature whilst the remaing to operate normally,
Can connection plar be used for ip phones ?
If I understand correct you have an IP Phone that whenever you if the handset you want to dial a predefined number all the time.
Under the ephone-dn, use the trunk command with the destination number.
e.g.
ephone-dn 3
number 1001
trunk 1002
When you lift the handset on extension 1001 it will automaticlly dial 1002.
Cheers,
Mike.
Plse rate helpful posts.
hi,
thanks for that, will try it next week and let you know
104
