CME "CFA Rules" ?
Quick question. Is is possible to allow a user to dial a number, but block him from CFA to the same number. For Example: A user is allowed to call Mobile numbers, but is not supposed to CFA to a Mobile numbers. Anyone try this?
Re: CME "CFA Rules" ?
hi i suppose we can assign a CSS to the CFA so tht calls may not be forwarded any numbers outside the CSS.
regards
kumars
Using Call Manger Express?
Hall of Fame Super Gold
Kumar,
the question is about CME, not CM, so CSS do not apply.
Fulcherke, if you're trying to prevent call-forward to external numbers, the easier way is to limit tha maximum number of digits. You can do that with "call-forward max-length" under ephone-dn-template.
Not really to external numbers, but to specific numbers. Normally I would agree with your assessment about the Max number of digits. However, this is a SRST CME for a large company with a long internal number plan. In Germany (where I am at) there is not a set 10 digit number dial plan, so I can not set a max-number without colliding with the users right to CFA Internally. Is there such a thing as Cor lists that can be applied to CFA? I know this is an off the wall question, but I figured someone might have tried it out.
It may be a bit complicated to do that.
The reason is because I think the "transfer-pattern" command do not apply to CF.
I will revert back to you once I can suggest a solution.
164
