We have an old router that now is in a production environment :
The cme is a 2611XM router with ios c2600-ipvoice-mz.123-11.YZ2.bin
We have some issues with these versions (3,2 AND 3,3) and we need to move to the latest available version for this model and for these specs 126/32 flash
can you provide one ios for this router ?
HEADOFFICE#show version
Cisco IOS Software, C2600 Software (C2600-IPVOICE-M), Version 12.3(11)YZ2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 08-Aug-07 20:39 by dchih
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
PJC_HEADOFFICE uptime is 1 hour, 9 minutes
System returned to ROM by reload at 11:55:00 CY Wed Mar 28 2012
System restarted at 12:03:14 CY Wed Mar 28 2012
System image file is "flash:c2600-ipvoice-mz.123-11.YZ2.bin"
Cisco 2611XM (MPC860P) processor (revision 0x300) with 125990K/5082K bytes of memory.
Processor board ID JAE0821HUXG (1409391963)
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
1 Serial interface
2 ISDN Basic Rate interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
HEADOFFICE#show telephony-service
CONFIG (Version=3.2)
Version 3.2
Cisco CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 10.0.10.254 port 2000
load 7910 P00403020214
load 7960-7940 P0030702T023
max-ephones 24
max-dn 48
max-conferences 4
dspfarm units 0
dspfarm transcode sessions 0
hunt-group report delay 1 hours
max-redirect 5
moh moh-greek.wav
time-format 12
date-format dd-mm-yy
timezone 0 Greenwich Standard Time
transfer-pattern 9T
keepalive 30
timeout interdigit 3
timeout busy 10
timeout ringing 180
caller-id name-only: enable
system message P.C. Splash
web admin system name admin password admin1
web admin customer name Customer
edit DN through Web: enabled.
edit TIME through web: enabled.
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 Mar 08 2012 10:43:41
transfer-system full-consult
local directory service: enabled.
Please rate all useful posts
Chrysostomos
""The Most Successful People Are Those Who Are Good At Plan B""
