CME ROUTER 2611 XM
We have an old router that now is in a production environment :
The cme is a 2611XM router with ios c2600-ipvoice-mz.123-11.YZ2.bin
We have some issues with these versions (3,2 AND 3,3) and we need to move to the latest available version for this model and for these specs 126/32 flash
can you provide one ios for this router ?
HEADOFFICE#show  version
Cisco IOS Software, C2600 Software (C2600-IPVOICE-M), Version 12.3(11)YZ2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 08-Aug-07 20:39 by dchih
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
PJC_HEADOFFICE uptime is 1 hour, 9 minutes
System returned to ROM by reload at 11:55:00 CY Wed Mar 28 2012
System restarted at 12:03:14 CY Wed Mar 28 2012
System image file is "flash:c2600-ipvoice-mz.123-11.YZ2.bin"
Cisco 2611XM (MPC860P) processor (revision 0x300) with 125990K/5082K bytes of memory.
Processor board ID JAE0821HUXG (1409391963)
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
1 Serial interface
2 ISDN Basic Rate interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
HEADOFFICE#show  telephony-service
CONFIG (Version=3.2)
Version 3.2
Cisco CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 10.0.10.254 port 2000
load 7910 P00403020214
load 7960-7940 P0030702T023
max-ephones 24
max-dn 48
max-conferences 4
dspfarm units 0
dspfarm transcode sessions 0
hunt-group report delay 1 hours
max-redirect 5
moh moh-greek.wav
time-format 12
date-format dd-mm-yy
timezone 0 Greenwich Standard Time
transfer-pattern 9T
keepalive 30
timeout interdigit 3
timeout busy 10
timeout ringing 180
caller-id name-only: enable
system message P.C. Splash
web admin system name admin  password admin1
web admin customer name Customer
edit DN through Web:  enabled.
edit TIME through web:  enabled.
Log (table parameters):
     max-size: 150
     retain-timer: 15
create cnf-files version-stamp 7960 Mar 08 2012 10:43:41
transfer-system full-consult
local directory service: enabled.
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
1 REPLY
Hall of Fame Super Gold
CME ROUTER 2611 XM
The 2611 is totally obsolete and you will not have good results using it.
Anyway, you can ask your reputable consultant or UC certified cisco partner for help.
744
