CME RP to CUCM RP
I have an update from CME to CUCM configuration , i have a solution VOIP between 14 sites using CME.I need to know best solution for VOIP . I have to upgrade my solution from CME to CUCM. I have to register all remote sites gateway as H323 to do VOIP calls ?. Can i do MGCP ?.
VIP Super Bronze
CME RP to CUCM RP
You are better of doing H323, howver if you want to use MGCP, then MGCP doesnt use dial-peers. Your E1 channel is controlled by CUCM and calls are routed directly from the gateway to CUCM...
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: CME RP to CUCM RP
Aokanlawn
Firstly thank you for your answer and i am so pleased that expert as you help me.I know all of that , my issue as you know on CME , we did dial-peer with session-target ipv4:X.X.X.X  , where X.X.X.X the IP address of remote site. My issue for MGCP , how can the call will route to the remote site without any information about the remote site IP or i have to add all of these gateways as MGCP Gws?. Other Question what about H323 solution , i have to register all remote gateways or CMEs to my CUCM
VIP Super Bronze
CME RP to CUCM RP
Let me see if I understand you correctly..
1. Currently you have 4 sittes each running CCME
2. You want to migrate these to CUCM.
If this is correct then here is what you need to do
1. Add your CCME gateways as H323 gateways anc ofngiure each of them to route calls to CUCM using voip dial-peers
2. Calls to remote sites will be routed by CUCM,hence you dont need any configuration as you have before...
When all your sites are on CUCM, CUCM will route calls to all the phones. The only dial-peers you need will be for calls to PSTN and calls from PSTN
CME RP to CUCM RP
Thanks for your help , that what i need to confimr about. I will do a test after that i will update you about.
VIP Super Bronze
CME RP to CUCM RP
OK..Let me get this.. Is this correct?
IP Phone--->.>---CUCM--->>>H323 Gateway-->>>--CCME
I will need you to send the ff log from both the h323 gateway and ccme gateway
  • debug voip ccapi inout
Do you know you can register your CCME as H323 gateway to the CUCM and send calls directly to it?
VIP Super Bronze
CME RP to CUCM RP
Ok..So you made a call from CCME on extension 39946 to CUCM on extension 22666..The call macthed outbound dial-peer 6..and it was disconnected due to a codec related issue..
-HASA-VG#
*Nov 14 13:18:08.363: //33766/0074CDCE0200/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x13F18014, Call Id=33766
  Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
Can you try this please..
conf t
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g711alaw
Then apply it to dial-peer 6...
dial-peer voice 6 voip
voice-class codec 1
Test again and send me the ff if it doesnt work...Please ensure you are testing from the same number etc
debug h225 asn1
debug h245 asn1
170
