Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CME Sccp phones
I have 7942 phones and they are registered on the CME router, but i see the attached logs in debug,so i am worried why that so ????, one of my colleague also receiving the same logs on his router but his 7942 phones are not registering.
thanks
Hall of Fame Super Silver
Looks like normal
Looks like normal unregistration of the phone due to either phone being disconnected or reset, etc.
Dear Chris,the logs seen are
Dear Chris,
the logs seen are when the phone is connected to the network and it is trying to update English_United_States/mk-sccp.jar file and then reset himself and boots again then it try to find the ctl,itl files where the error are seen 09:18:19: TFTP: Sending error 1 No such file,
thanks
Dears,Any hint pls.thanks
Dears,
Any hint pls.
thanks
What is the actual issue here
What is the actual issue here?
Those messages are expected unless you have secured environment to download CTL file, etc.
Dear Chris,As you being the
Dear Chris,
As you being the community expert, can you elaborate more how i can find out it is secured environment or non secured in my CME??
thanks
55
