CME SDM
Hi All,
when I use SDM for the CME, after couple of activity in the SDM, CME restarts. any suggestion would be appreciated.
thanks
Alex
Hall of Fame Super Gold
Re: CME SDM
Software crash, upgrade to latest image like 12.4.9 or 11T. Ugrade SDM also and try again.
Re: CME SDM
I accidentally delete one file that related to SDM. I need to delete all file related to SDM and reinstall it. would you please show me which file is the SDM files? also can I install SDM again through PC?
show flash in the attachment.
thanks
ALex
Re: CME SDM
I think these are the SDM files. I've seen somewhere documentation that explains what is what.
You may want to try to keep files into directories to keep things neater and easier to tell apart. It works ok unless you have SIP phones, for which files _must_ be kept in the main directory. Looks like the code is not smart enough to discriminate platforms on which directories are suppored, and CCME is supported on both. Sigh.
2 -rw- 1038 Jan 13 2007 22:42:44 +01:00 home.shtml
3 -rw- 2746 Jan 13 2007 22:42:46 +01:00 sdmconfig-2801.cfg
4 -rw- 113152 Jan 13 2007 22:42:50 +01:00 home.tar
5 -rw- 1069568 Jan 13 2007 22:43:14 +01:00 common.tar
6 -rw- 4787200 Jan 13 2007 22:44:58 +01:00 sdm.tar
7 -rw- 860672 Jan 13 2007 22:45:30 +01:00 es.tar
18 -rw- 491213 Jul 13 2006 21:28:44 +02:00 128MB.sdf
19 -rw- 1684577 Jul 13 2006 21:29:20 +02:00 securedesktop-ios-3.1.1.27-k9.pkg
20 -rw- 398305 Jul 13 2006 21:29:46 +02:00 sslclient-win-1.1.0.154.pkg
173
