CME- Send caller straight to VM
Gurus,
For example, in the case of the secretary who knows the boss is busy, is there a way for her to send/transfer the caller directly into the boss's VM box, without the ringing of the phone first?
CME and CUE.
Thanks for the time,
-Michael
Hall of Fame Super Gold
Re: CME- Send caller straight to VM
If I'm not worng, this feature now appeared in CME 4.3
However, remember that some callers are able to tell from the ring pattern that they have been transferred directly and can complain about the low priority given to their call.
With that good info from Paulo, here is a link to the config guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmevmail.html#wp1041576
Hall of Fame Super Red
Hi Michael,
Just to add a note to the great info from Paolo and Matt (you guys Rock!). Here is another method (if you don't have CME 4.3), the steps required are nicely detailed in this good Tech Note;
Transfer a Caller Directly into a Unity Express Mailbox
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a00802ab979.shtml#cue_int_ccm_exp
Hope this helps!
Rob
Hey, thanks for all the great responses.
-Michael
All,
Here is another simpler was of doing this;
ephone-dn 1
number 8.... (assuming that the ext length is 4 and number 8 will be used to directly xfer to VM)
call-forward all
translation-profile outgoing XferVM
voice translation-rule 8
rule 1 /^8\(.*\)/ /\1/
voice translation-profile XferVM
translate redirect-called 8
215
