10-07-2008 04:16 PM - edited 03-15-2019 01:47 PM
We are upgrading our circuit from 16 channels to a full E1 with 30 channels. I am able to change the pri-group timeslots to 1-31. When I sh ip interface brief I see all the channels displayed. My question is does the int S0/0/0:15 need to be modified to s0/0/0:31 to reflect the other channels or will all the channels still be available under the S0/0/0:15?
Any help would be greatly appreciated. Thank you!
10-07-2008 05:23 PM
u dont need to change it
S0/0/0:15 is the one u need
basicly the channel 16 is the D channel for E1 if u use all chaneels or 4 channells
if helpful Rate
10-07-2008 07:06 PM
Hi Marwan,
Thanks so much for replying. I am changing from 16 channels to 31 channels. Doesn't the serial interface have to reflect the 31 channels instead of the 16? How would I make that change?
Thank you!
10-07-2008 07:26 PM
the channel 16 will remain the D channel regardless howmany channels u are running
if helpful Rate
10-07-2008 11:35 PM
for your information
pri-group timeslots (1-31) for E1. This command associates the specified timeslots as ISDN channels. If you do not specify timeslots, all B-channels are associated to the PRI group. It is important to understand that the D-channel is always added to the pri-group, even if it is not explicitly specified, because it is required for signaling
hope this helpful
10-08-2008 04:48 AM
Hi Marwan,
Thank you so much for your quick response. I appreciate all your help!
10-08-2008 04:49 AM
u welcome
please, rate the helpful post
