CME Setup
Does anyone have a document that talks about how to setup CME for the first time?
Re: CME Setup
What version of CME are you running?
Here is the admin guide
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
Hope that helped, if so please rate.
Re: CME Setup
Can you tell me where I find this information? I think I might need to purchase a license. How do I tell if I have a license for CME?
Re: CME Setup
This book is amazing. It will walk you through the installation of CME.
http://www.ciscopress.com/bookstore/product.asp?isbn=1587202077
Re: CME Setup
The number of phones and extensions you can support on your CME is based on router platform and IOS version.
Check this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_device_support_tables_list.html
and here is the CME version/IOS compatibility matrix:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Re: CME Setup
Hey Guys,
Thanks for the quick response. So are you saying you don't have to install a license file? If you do, can you tell me the commend to run to figure out if my router already has it? Also, Can the router be a TFTP for the phone, or how does that work?
Re: CME Setup
You don't have to install a license file. And, yes, the router can be the tftp-server for the phones.
Re: CME Setup
SCCP: Setting Up Cisco Unified CME
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesystm.html#wp1023245
Router is the TFTP, the guides have all the info on this.
the licensing is honour based, so even if you don't need an actual file you do need to buy it for legal terms. similar to IPC before, the license was just a piece of paper but you had to buy if to be licensed to use it even if it's not really necessary to install or use IPC
java
if this helps, please rate
java
www.cisco.com/go/pdi
270
