CME setup.
I'm attempting to configure the Call Manager Express 4.1 on a 2901 router.  I have 2 Cisco IP Phone 7961G's.  My connection to the network backbone is via a Catalyst 3560-X-Series switch hosting the local DHCP and NAT'ing to the network backbone.  My question is concerning VLAN's and DHCP hosting.  Will I have better success with the router hosting the local DHCP and/or will creating a voice-VLAN on the designated ports for the phones back to the dedicated port on the router?
v/r,
Shane
Router Config:
_______________________________
Current configuration : 3918 bytes
! Last configuration change at 15:27:09 UTC Wed Apr 11 2012 by router
version 15.1
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name yourdomain.com
voice-card 0
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server expires max 1200 min 300
voice register global
mode cme
license udi pid CISCO2901/K9 sn XXXXXXXXXXXXXXXXX
hw-module pvdm 0/0
redundancy
interface Loopback1
no ip address
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address XXX.XXX.XXX.XXX 255.0.0.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description $ES_LAN$
ip address XXX.XXX.XXX.XXX 255.255.255.0
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static XXX.XXX.XXX.XXX XXX.XXX.XXX.XXX
ip nat outside source static XXX.XXX.XXX.XXX XXX.XXX.XXX.XXX
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route XXX.XXX.XXX.XXX 255.255.255.0 XXX.XXX.XXX.XXX
access-list 23 permit XXX.XXX.XXX.XXX 0.0.0.255
access-list 100 permit ip host XXX.XXX.XXX.XXX any
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 0 0
privilege level 15
password XXXXXXXXXXXXXX
login
transport input telnet ssh
line vty 5 15
access-class 23 in
exec-timeout 0 0
privilege level 15
password XXXXXXXXXXXXXXX
login
scheduler allocate 20000 1000
end
router#
Switch Config:
_____________________________________________
Building configuration...
Current configuration : 6307 bytes
version 12.2
no service pad
hostname switch
boot-start-marker
boot-end-marker
enable secret XXXXXXXXXXX
enable password XXXXXXXX
no aaa new-model
clock timezone UTC -5
clock summer-time UTC recurring
system mtu routing 1500
no ip dhcp conflict logging
ip dhcp pool voice
   network XXX.XXX.XXX.XXX 255.255.255.248
no ip domain-lookup
crypto pki trustpoint TP-self-signed-494936704
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-494936704
revocation-check none
rsakeypair TP-self-signed-494936704
spanning-tree mode pvst
auto qos srnd4
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
switchport access vlan 10
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
interface Vlan10
interface Vlan20
no ip address
ip http server
ip sla enable reaction-alerts
snmp-server community
snmp-server location XXXXXX
snmp-server contact XXXXXXXXXXX
line con 0
exec-timeout 1440 0
line vty 0 4
exec-timeout 0 0
login
line vty 5 15
exec-timeout 0 0
login
monitor session 1 source interface Gi0/12
monitor session 1 destination interface Gi0/23
end
switch#
Everyone's tags (2)
1 REPLY
Hall of Fame Super Gold
CME setup.
Wrong forum, try "ip telephony". You can move the post using the control panel on the right.
436
