Anonymous
N/A
CME - shared line ring setting when primary phone line active
Hi All,
I have a problem for the CME configuration.
A end user ephone (CP7965G) have 2 DN, 1st line is end user no. , the 2nd line is boss sharded line.
When the end user using line 1 (1st phone line active in this time), a new call calling to his boss, the 2nd line is flashing but didn't ring.
I understand when I using CUCM just set the "Ring Setting (Phone Active)" to "ring" in the boss line,
but in CME, how can I allow the 2nd line ringing in CME command?
Many Thanks.
Ivan
Everyone's tags (2)
Hall of Fame Super Gold
I think you want call-waiting signal, not ring?
Both options are configured under ephone-dn and ephone.
You can reference the documentation for more information.
Anonymous
N/A
Thanks for your reply,
I tried use the call-waiting ring command, but it didn't work.
For the 1st line active, I want 2nd line ring at the phone speaker (not hear at headset) when new incoming call arrived.
Hall of Fame Super Red
Hi Ivan,
Can you please post up the ephone configs for the end user
and bosses phone
Cheers!
Rob
Anonymous
N/A
Thanks Rob.
Here is the config,  ephone 1 is the Boss phone, ephone 2 is the Secretary phone.
Secretary 3rd botton is his boss line, when 1st is active and someone call his boss, the 3rd button need flash and ringing at the phone speaker.
ephone-template  1
exclude em
softkeys hold  Resume Newcall Select Join
softkeys idle  Redial Cfwdall Pickup Gpickup
softkeys seized  Redial Endcall Pickup Gpickup Cfwdall
softkeys alerting  Endcall
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn ConfList Select Join
softkeys ringing  Answer Dnd
button-layout 1-2 line
button-layout 3-4 speed-dial
ephone-template  2
exclude em
button-layout 1-4 line
button-layout 6-8,19-30 speed-dial
button-layout 5,9-18 blf-speed-dial
ephone-dn  1  dual-line
number 888
pickup-group 1
label Boss
description 29999888
name Boss
ephone-dn-template 1
ephone-dn  9  dual-line
number 889
pickup-group 1
label Secretary
description 29999889
name Secretary
ephone  1
mac-address 1111.1111.1111
ephone-template 1
max-calls-per-button 2
username "Boss" password 123
speed-dial 1 889 label "Secretary"
speed-dial 2 890 label "Secretary2"
type 6941
button  1s1 2s101
ephone  2
mac-address 2222.2222.2222
ephone-template 2
username "Secretary"
type 7965 addon 1 7916-24
auto-line 1 answer-incoming
button  1:9 2o109,110,118 3:1 4:101
button  5:28
Re: CME - shared line ring setting when primary phone line activ
Hi Ivan,
You may be seeing this behavior;
All phones sharing the common directory number can initate and receive calls at the same time. Calls to
the mixed shared line ring simultaneously on all phones without active calls and any of these phones can
answer the incoming calls.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.pdf
Cheers!
Rob
2629
