Community Member
CME - ShoreTel Mobility router, licensing question
I`m about to connect ShoreTel Mobility Router with my CME running on ISR3945E over SIP. The idea is that smartphone users with ShoreTel application installed will be routed from ShoreTel device to CME via SIP (same datacenter, connected directly with a cable), and then leave to rest of the world through PSTN
I will have around 30 these connections. Now, I`m asking here what licenses do I need on the Cisco side, because my Cisco partner is not very responsive on these matters
Thank you in advance!
Milos
Everyone's tags (6)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
No license is needed.
Community Member
Thank you Paolo! Cisco Support forums prove more useful than official partner channels once again
Thank you for the nice rating and good luck!
563
