CME Silent Rings Immediately followed by Audible Rings
For the above code, I get 6 silent rings on my 2nd line. I want only the 1st 3 rings to be silent rings and the last 3 rings to be normal audible rings. I'll appreciate a solution. Thanks all.
ephone 1
mac-address aaaa.bbbb.cccc
type 7960
button 1:12 2s15
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CME Silent Rings Immediately followed by Audible Rings
Hi, CCME doesn't support increasing volume rings, the only thing you can do is configure CFNA from a silent ring button to another that has audible ring:
ephone-dn 15 dual-line
call-forward noan 416 timeout 15
ephone-dn 16 dual-line
number 416
ephone 1
button 2s15 3:16
number 416
ephone 1
button 2s15 3:16
I only have 7941 phones and so there is no 3rd button. So I'll appreciate a solution for two button phones.
Thanks in advance.....
Use first button on overlay as necessary with call waiting and 2nd button for silent ting, or viceversa.
Thanks. It worked
147
