CME - Simultaneously ring on 7912 IP-phone and dial-peer (pots and voip)
At first - excuse me for my English
I have
1760-V router with CME 4.0
5 - 7912 ip phone (Skinny)
2 - SIP ip phone from D-Link
one FXS card with two FXS port
I write dial-peer for Sip phone
#dial-peer voice 1010 voip
#destination-pattern 1010
#session protocol sipv2
#session target ipv4:192.168.52.100
I write dial-peer for FXS
#dial-peer voice 1012 pots
#destination-pattern 1012
#port 2/0
and CME create DN from 1000 to 1004
When i want simultaneously ring on two or more 7912 i use overlay in
ephone configuration
#ephone 1
#button 1o1,2
I want produce simultaneously ring not only 7912 phone.
For example - if i have call on 1100 number, I want have a ring on phone with number 1000, SIP phone on number 1010 and phone on FXS port 1012.
I read many documents about voice on cisco.com, and I don't understand if it possible or not, and if it possible how i can configure it.
Thank You for attention.
Hall of Fame Super Gold
Re: CME - Simultaneously ring on 7912 IP-phone and dial-peer (po
for this you will configure a voice hunt-group with the parallel option. You will list the numbers to match by eFXS, FXS, application, or VoIP dial-peer.
I do this, but i have error message
>Part of config
telephony-service
ephone-dn 1
number 1000
ephone 1
button 1:1
#voice hunt-group 1 parallel
#list 1010,1000
Number 1010 is not a valid voice register dn. Re-enter 'list.'
You haven't configured the SIP phones numbers under the voice register dn and pool sections.
That will avoid you configuring a dial-peer/
Guide to SIP phones and CCME:
http://cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_book09186a008052da6b.html
I read this document and i don't understand how i can configured SIP phone other than Cisco SIP phone.
I've the same problem on my 1751V.
At the moment i solved the problem with a time-out and i put the FXS extension in the final tag
#dial-peer voice 10 voip
#dial-peer voice 12 voip
#dial-peer voice 11 pots
#list 10,12
#timeout 20
#final 11
1231
