CME - Single Number Reach - 2 SNRs on 2 different lines
Hi guys,
why doesn't the CME permit 2 SNRs on 2 different lines?
it says: "DN 1 is also SNR. Can't have a 2nd one with DN 2".
Example:
ephone-dn  1 dual-line
number 100
mobility
snr 001234567890 delay 0 timeout 60
ephone-dn  2 dual-line
number 200
mobility
snr 009876543210 delay 0 timeout 60
ephone  1
button  1:1 2s2
CME Version: 8.6
Thanks a lot.
Cristian
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Cristian,
That restriction is shown here
SCCP: Configuring Single Number Reach
To enable the Single Number Reach (SNR) feature on SCCP IP phones, perform the following steps.
Prerequisites
Cisco Unified CME 7.1 or a later version
Cisco IP Communicator requires version 2.1.4 or later
Restrictions
Each IP phone supports only one SNR directory number.
SNR feature is not supported for the following:
SCCP-controlled analog FXS phones
MLPP calls
Secure calls
Video calls
Hunt group directory numbers (voice or ephone)
MWI directory numbers
Trunk directory numbers
An overlay set can support only one SNR directory number and that directory number must be the primary directory number.
Call forward no answer (CFNA), configured with the call-forward noan command, is disabled if SNR is configured on the directory number. To forward unanswered calls to voice mail, use the cfwd-noan keyword in the snr command.
Call forwarding of unanswered calls, configured with the cfwd-noan keyword in the snr command, is not supported for PSTN calls from FXO trunks because the calls connect immediately.
Calls always remain private. If a call is answered on a remote phone, the desktop IP phone can not listen to the call unless it resumes the call.
U.S. English is the only locale supported for SNR calls.
You may want to look into CME 9.0 which has this enhancement;
Virtual SNR DN for Cisco Unified SCCP IP Phones
A virtual SNR DN is a DN not associated with any registered phone. It can be called, forwarded to a preconfigured mobile phone, or put on an Auto Hold state when the mobile phone answers the call or the time delay is reached. In the Auto Hold state, the DN can either be floating or unregistered. A floating DN is a DN not configured for any phone while an unregistered DN is one associated with phones not registered to a Cisco Unified CME system.
Before Cisco Unified CME 9.0, an SNR DN feature did not launch when the SNR DN was not associated with any registered phone. Although a call could be forwarded to the mobile phone using the call-forward busy command, the SNR DN had to be configured under a phone. Users who were assigned floating DNs could not forward calls unless they had a phone assigned to them.
In Cisco Unified CME 9.0 and later versions, an SNR DN is not required to be associated with a registered phone to have the SNR DN feature launched. A call can be made to a virtual SNR DN and the SNR feature can be launched even when the SNR DN is not associated with any phone. A call to a virtual SNR DN can be forwarded to an auto-attendant service when the preconfigured mobile phone is out of service and the voice mail can be retrieved using the telephone or extension number assigned to the voice mailbox.
Although the virtual SNR DN feature is designed for SNR DNs that are not associated with registered phones, this feature also supports virtual SNR DNs that complete phone registration or login and registered DNs that become virtual when all associated registered phones become unregistered.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesnr.html#wp1011683
Cheers!
Rob
Hi Cristian,
Prerequisites
Restrictions
MLPP calls
Secure calls
Video calls
Cheers!
Rob
thanks!
1666
