02-12-2014 04:01 AM - edited 03-16-2019 09:43 PM
Hi everybody...
I have CME connected to ISP by SIP for voice.
Call flow is
PSTN - SIP- CME-SCCP-ip phone
this work fine...
I can manually transfer call to anither CM
PSTN - SIP- CME-SCCP-ip phone-Call Transfer - H323 - UCM -H323-gateway PSTN
But iа I configure CFA on ip phone call is failed....
What debug should i use to define the reason...
What should I configure to resolve problem?
Thank you very much
02-12-2014 04:06 AM
Did you applied call-forward and transfer pattern in telephony service ?
Like this..
(config-telephony)#call-forward pattern .T
(config-telephony)#transfer-pattern .T
Manish
02-12-2014 04:11 AM
Yes It is configured. I can transfer call manually ...
02-12-2014 04:14 AM
Can you attach your CME config please.
Manish
02-12-2014 04:24 AM
Yes I can... but config is very complex...
I need determy reason first ... for this show and debug need be gathered...
02-12-2014 05:31 AM
Hi Chernyakov,
Are you getting this issue only when you are forwarding your call out of the H.323 or internally?
Please try by forwarding your call internally i.e. to the phone which is registered to same CME.
You can do that in multiple ways as follow:-
OR
ephone-dn x
call-forward all XXXXXexit
If this works then you can proceed with below steps for analysis:-
Please share debug
Nishant Savalia
02-12-2014 05:41 AM
Ok.
Can you send ephone-dn / ephone config from which you are forwarding calls and also telephony service config.
You are setting CFA to which number ? Internal CME ext or CUCM ext or external number from H323 GW?
When you setup CFA to an external number which is going through SIP GW then also call fails ?
Collect below debug logs.- "debug voice ccapi in out" "debug isdn q931" for failing call.
Manish
02-12-2014 05:46 AM
Does the H323 GW configuration on CUCM, have a CSS assigned that would match a RP to go out the PSTN H323 GW?
Yosh
02-12-2014 05:48 AM
My bad I just re-read what you wrote. Could you post the telephony-service config and the ephone config.
Yosh
