CME SIP configuration
I've a CME (3845) with couple of phones registered to it. Im trying to connect it to HIQ (call agent)
Phone 5001
Phone 5002   Call Manager Express 172.17.2.6 }  - - - -SIP CONNECT INTERFACE ----{ 172.17.2.226 HIQ/Siemens } {phone 140858214XX}
Phone 5003
Kindly brief me on what all I need to configure?
Sylvester
User Access Verification
Password:
CME>en
Password:
CME#
CME#
CME#show run
Building configuration...
Current configuration : 5229 bytes
! Last configuration change at 11:45:39 UTC Fri Dec 4 2009
! NVRAM config last updated at 11:42:14 UTC Fri Dec 4 2009
version 12.4
hostname CME
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/3
logging message-counter syslog
enable secret 5 $1$zRDc$kVJuuxoegWPZI2kTqjAFt0
no aaa new-model
no network-clock-participate slot 4
no network-clock-participate wic 1
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
ntp master
voice-card 0
voice-card 4
voice service voip
allow-connections sip to sip
redirect ip2ip
fax protocol cisco
sip
  registrar server
  no call service stop
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address 172.17.2.6 port 5060
max-dn 10
max-pool 10
load 7960-7940 P0S3-06-0-00
authenticate register
tftp-path flash:
file text
create profile sync 0002270562017059
voice register dn  1
number 5001
voice register dn  2
number 5002
voice register pool  1
id mac 0000.0000.0000
number 1 dn 1
username 5001 password 5001
codec g711ulaw
voice register pool  2
number 1 dn 2
username 5002 password 5002
codec g711ulaw
voice translation-rule 1
rule 1 /14085821475/ /5001/
voice translation-profile AutoAttendant
translate called 1
archive
log config
  hidekeys
controller E1 0/1/0
controller E1 0/1/1
no ip ftp passive
ip ftp source-interface GigabitEthernet0/0
ip ftp username cisco
ip ftp password cisco123
ip address 172.17.2.6 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/0/0
no ip address
shutdown
interface Serial0/2/0
no ip address
shutdown
clock rate 2000000
interface Serial0/2/1
no ip address
shutdown
clock rate 2000000
interface FastEthernet1/0
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Service-Engine2/0
no ip address
shutdown
interface Vlan1
no ip address
ip default-gateway 172.17.2.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.17.2.1
ip route 172.17.1.0 255.255.255.0 172.17.2.1
ip http server
ip http path flash:
tftp-server flash:RingList.xml
tftp-server flash:term65.default.loads
tftp-server flash:P0S3-06-0-00.bin
tftp-server flash:P0S3-06-0-00.sbn
tftp-server flash:P003-8-12-00.sbn
tftp-server flash:ATA030201SIP050616A.zup
control-plane
voice-port 4/0/0
connection plar 1001
caller-id enable
voice-port 4/0/1
voice-port 4/1/0
voice-port 4/1/1
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
dial-peer voice 5002 voip
preference 1
destination-pattern 5...
b2bua
session protocol sipv2
session target ipv4:172.17.2.6
dtmf-relay sip-notify
playout-delay maximum 300
codec g711ulaw
no vad
dial-peer voice 5001 voip
preference 1
b2bua
codec g711ulaw
no vad
dial-peer voice 1 voip
description **Incoming call from HiQ**
translation-profile incoming AutoAttendant
session target ipv4:172.17.2.226
incoming called-number 1408582....
dtmf-relay rtp-nte
no vad
dial-peer voice 2 voip
description **Outgoing calls to HiQ**
destination-pattern 9[0-1]..........
session target ipv4:172.17.2.225
dtmf-relay rtp-nte
no vad
dial-peer voice 1408 voip
description **to Hiq**
destination-pattern 14085821475
voice-class codec 1
dtmf-relay rtp-nte
no vad
gateway
timer receive-rtp 1200
sip-ua
authentication username 14085821400 password 7 124851474A5E54567B7F7478
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar ipv4:172.17.2.6 expires 3600
sip-server ipv4:172.17.2.225
host-registrar
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 10
max-dn 10
ip source-address 172.17.2.6 port 5060
load 7960-7940 P003-8-12-00
load ata ATA030201SIP050616A
max-conferences 4 gain -6
web admin system name admin password cisco
dn-webedit
time-webedit
transfer-system full-consult
login timeout 10
create cnf-files version-stamp 7960 Dec 02 2009 10:11:18
banner exec ^C^C
line con 0
line aux 0
line 130
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120
line vty 0 4
password letmein
login
scheduler allocate 20000 1000
end
CME#
Re: CME SIP configuration
I can't help with the Siemans, but this link might help get you going:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f9666.shtml
-- please remember to rate and mark answered helpful posts --
Ok done Deal. I was trying to configure "SIP CONNECT INTERFACE"
Now, I have the users created in Hiq, and same users gets registered on CME, (both SIP and SCCP) , now working on h323. If i can get that working, will post.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
fax protocol cisco
sip
  registrar server
  asserted-id pai
voice class codec 1
codec preference 1 g729r8
codec preference 2 g723r63
codec preference 3 g711ulaw
codec preference 4 g711alaw
codec preference 5 g728
codec preference 6 g726r16
mode cme
max-dn 5
max-pool 5
tftp-path flash:
create profile sync 0006854282049246
voice register dn  1
number 1408xxx1483
voice register dn  2
number 1408xxx1484
number 1 dn 1
username 1408xxx1483 password 1408xxx1483
codec g711ulaw
number 1 dn 2
username 1408xxx1484 password 1408xxx1484
codec g711ulaw
description "Outgoing calls to HIQ"
destination-pattern 1408xxx....
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session target sip-server
dtmf-relay rtp-nte
no vad
description "calls coming from Hiq"
voice-class codec 1
incoming called-number 1408.......
gateway
sip-ua
credentials username 1408xxx1480 password 7 0870181E514C5D45435F5454 realm 172.17.2.225
no remote-party-id
retry invite 2
retry register 10
retry options 2
timers connect 100
mwi-server ipv4:172.17.2.225 expires 1800 port 5060 transport udp unsolicited
registrar ipv4:172.17.2.225 expires 1800
notify telephone-event max-duration 500
gatekeeper
shutdown
telephony-service
max-ephones 3
max-dn 3
ip source-address 172.17.2.6 port 2000
auto assign 1 to 3
dialplan-pattern 1 1408xxx1... extension-length 4
max-conferences 12 gain -6
create cnf-files version-stamp 7960 Dec 08 2009 10:30:21
ephone-dn  1  dual-line
number 1480 no-reg primary
ephone-dn  2  dual-line
number 1481 no-reg both
ephone-dn  3  dual-line
number 1482
ephone  1
no phone-ui speeddial-fastdial
no phone-ui snr
no multicast-moh
mac-address 001C.234F.BD80
keepalive 30 auxiliary 0
codec g729r8 pre-ietf
type CIPC
button  1:1 2:2
ephone  2
no phone-ui snr
no multicast-moh
ephone  3
no phone-ui snr
no multicast-moh
4790
