CME SIP Directory
We are running CME 8.6. We have nearly 100 SCCP Phones and 5 SIP (9971) Phones on this CME. The SIP Phones are being projected as the 'top of the line' model and should be better then there counterparts..right?? But we cannot see the local directory of the SCCP Phones on the 9971 (SIP) Phones. Is there any way/workaround to see the SCCP directory in the SIP Phones?
Saif
CME SIP Directory
what do you mean you can't see the local directory? Is there an error message or just blank screen?
Also, is the voice register global section set up correctly?
G.
CME SIP Directory
It says " No contacts available"
CME SIP Directory
Just to confirm, the voice register global section contains a line starting with url directory, right?
G.
CME SIP Directory
@Gergely
No, I dont see any such command configured in 'voice register global'. Could you please advise what is the exact command to point it to SCCP local directory?
Saif
CME SIP Directory
well, I can't test it, but I guess
max-dn 5
max-po 5
mode cme
url directory
would do
G.
CME SIP Directory
HI,
Thats all done bro, the question here is that how to specify the exact URL for the SSCP CME in the SIP CME? You said the "url directory " but what that would be????
In case its an external directory, we have tons of documents that explain the url and its format but here its CME acting as directory server.
Saif
CME SIP Directory
Hmm. I guess http:///localdirectory
Also, remember to do create profile and then reset.
G.
CME SIP Directory
Nops, this does not work. Any other ideas from the gurus???? The whole idea is to enable localdirecotry for SIP Phones in CME.
Re: CME SIP Directory
Does sccp phones can see these five sip phones in their directory?
Can you share your voice register global and telephony service configs.
Manish
I'm unable to fetch Local directories of my other office in 8841 Phones. We have 2 CME Routers which are conneceted through SIP. This was working all well but not fetching local directories of each other locations since 2 Months. Could someone help me?
513
