CME SIP Phone and CUBE
Hi Guys,
I have the following setup
CUCM ---- GK--- CME
SIP phone is registered to CME and CME is also configured as CUBE. When i make call from CUCM IP phone to CME SIP phone, I do not have any problem. However if i call from CME SIP phone to CUCM i am having problem. Phone rings and when i pickup it get disconnect. When i call from CME SIP phone to CUCM IP Phone it suppose to be G729. However CME SIP phone does not invoke the CUBE transcoder which is configured on the CME.
I am not sure whether the is any special configuration required for SIP phone to invode CUBE which is configured on the same route.
I would appricate your help.
Thanks!!!
Ragu.
Hall of Fame Super Gold
Use G.711, that will save you a lot of trouble,
Thanks. However , i found that fast start need to be enable for incoming call on the CUCM trunk to GK as CME initiates fast start.
Re: CME SIP Phone and CUBE
You can review your transcoding dspfarm resources, you have a codec issue because the call signaling is working good.
Regards.
413
