CME sip phone call pickup fails, after trying, searching the web, I still can't get this to work. All attempts at "call pickup" results in "reorder" displayed and heard, all phones running sip.
Relevant parts of current config:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol cisco
sip
registrar server expires max 120 min 60
voice class codec 1
codec preference 1 g711ulaw
voice register global
mode cme
source-address 10.10.230.1 port 5060
max-dn 20
max-pool 42
load 7962 SIP42.8-5-4S
voicemail 3180
call-feature-uri pickup http://10.10.230.1/pickup
call-feature-uri gpickup http://10.10.230.1/gpickup
tftp-path flash:
create profile sync 0015560731128401
voice register dn 1
number 3001
call-forward b2bua noan 3180 timeout 20
pickup-call any-group
pickup-group 1
name BR2Phone1
mwi
voice register dn 2
number 3002
pickup-group 1
name BR2Phone2
mwi
voice register dn 3
number 3003
shared-line
voice register pool 1
id mac 0023.EBC7.2113
type 7962
number 1 dn 1
number 2 dn 3
dtmf-relay rtp-nte
codec g711ulaw
no keep-conference
voice register pool 2
id mac 0023.EBC7.19FF
type 7962
number 1 dn 2
number 2 dn 3
dtmf-relay rtp-nte
codec g711ulaw
no keep-conference
voice hunt-group 1 sequential
final 3000
list 3001,3002
timeout 10
pilot 3111
voice translation-rule 3000
rule 1 /^76303/ /3/
voice translation-profile strip7630
translate called 3000
voice-card 0
controller E1 0/1/0
pri-group timeslots 1-31
interface Loopback0
ip address 10.10.32.3 255.255.255.255
ip ospf network point-to-point
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.220
encapsulation dot1Q 220
ip address 10.10.220.1 255.255.255.0
interface FastEthernet0/0.230
encapsulation dot1Q 230
ip address 10.10.230.1 255.255.255.0
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
ip http server
no ip http secure-server
ip http path flash:
tftp-server flash:apps42.8-5-4TH1-6.sbn
tftp-server flash:cnu42.8-5-4TH1-6.sbn
tftp-server flash:cvm42sip.8-5-4TH1-6.sbn
tftp-server flash:dsp42.8-5-4TH1-6.sbn
tftp-server flash:jar42sip.8-5-4TH1-6.sbn
tftp-server flash:SIP42.8-5-4S.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
voice-port 0/1/0:15
translation-profile incoming strip7630
dial-peer voice 3000 pots
incoming called-number 3...
direct-inward-dial
telephony-service
authentication credential admin cisco
max-ephones 2
ip source-address 10.10.230.1 port 2000
service directed-pickup gpickup
max-conferences 8 gain -6
web admin system name admin password cisco
dn-webedit
time-webedit
transfer-system full-consult
fac standard
create cnf-files version-stamp 7960 Jan 12 2010 19:21:45
