CME SIP phone huntgroup list limitation?
Hi all,
I would like to ask
In CME, does SIP phone huntgoup list has limitation?
Can I define 100 members(numbers) in the list? (if using hunt-group parallel)
Router(config)# voice hunt-group 4 parallel
Router(config-voice-hunt-group)# pilot 1000
Router(config-voice-hunt-group)# list 1001, 1002, 1003, 1004, ... .... ... , 1098, 1099, 1100
Thank you
Sam
Everyone's tags (2)
Such is discussed in the CME config guide
Added support for the following on IP phones running SCCP:
Maximum number of hunt groups in a system was increased from 20 to 100 and maximum number of agents in a hunt group was increased from 10 to 20.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
so, it is not possible to hunt for 100 numbers ?
I tried the following config, that has a main "hunt-group 1", contains sub group of "hunt-group 2", "hunt-group 3", and "hunt-group 4". .... but it seems only the first sub-group can be reached ...
voice hunt-group 1 parallel
pilot 1000
list 1100, 1200, 1300
voice hunt-group 2 parallel
pilot 1100
list 1101, 1102, 1103, ...... 1110
voice hunt-group 3 parallel
pilot 1200
list 1201, 1202, 1203, ....  1210
pilot 1300
list 1301, 1302, 1303, ....  1310
Do I make anything wrong and mistake?
Sam
1150
