CME SIP Phone to SCCP phone call transfer issue
Hi All
The incoming call transfer  I cannot possible to Sip to Sccp phone sccp to sccp is transfer is working .
Sip phone 8961
sccp phone 7945,6921
please check configuration
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service h450.2
 no supplementary-service h450.3
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
 sip
  registrar server expires max 300 min 60
oice register dn  1
 number 0
 call-forward b2bua noan 999 timeout 20
 allow watch
 name Operator
 label Operator
voice register pool  1
 id mac 1CAA.0710.0AC1
 type 8961 addon 1 CKEM
 number 1 dn 1
 template 1
 dtmf-relay rtp-nte sip-kpml sip-notify
 username cisco password cisco
 codec g711ulaw
 no vad
 camera
 video
telephony-service
 sdspfarm units 3
 sdspfarm tag 1 conference
 conference hardware
 conference transfer-pattern
 video
 no auto-reg-ephone
 max-ephones 100
 max-dn 250
 ip source-address 192.1.1.111 port 2000
 system message LCC_SIPOREX
 time-zone 31
 date-format dd-mm-yy
 voicemail 999
 mwi reg-e164
 max-conferences 8 gain -6
 web admin system name admin secret 5 $1$qHe3$xblvRD1ouV4jr8RcGUiMM.
 dn-webedit
 time-webedit
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
Thank you
1 ACCEPTED SOLUTION
Genius post, Martin!
Hi @,Try this config under
Hi @,
Try this config under the telephony-service globa configuration:
telephony-service
 call-park system application
After this, re-create both configuration files (in voice register global and telephony-service):
 no create profile
 create profile
telephony-service
 no create cnf-files
 create cnf-files
And restart the phones.
HTH.
Rgrds,
Martin, IT Specialist
Hi MartinThanks your replay i
Hi Martin
Thanks your replay i will check and update u .
HiIts problem solved thanks
Its problem solved thanks all
Good to hear that!Did you use
Good to hear that!
Did you use the commands that I provided you or did you fix it in other way? If so, please share it.
Don't forget to rate.
Rgrds,
Martin, IT Specialist.
Hi alli used this command its
Hi all
i used this command its working well
telephony-service
 no create profile
 create profile
telephony-service
 no create cnf-files
 create cnf-files
Thank you
If the option that I gave you
What do you get when you
What do you get when you press transfer? Fast busy tone? Can you configure the DN assigned to SIP as dual-line.
Rgds,
Wilmer
717
