CME SIP Pickup
Someone has a working config of CME using SIP Phone 3905 and with pickup working?
My issue is that pickup doesn't work.
When I press the feature button then pickup I get reorder tone.
I have configured pickup-group on voice register dn and the service directed pickup on telephony service. After that, I create cnf-files(on telephony-service) and create profile (on voice register global) and reset the phones. Anyone know If I am missing something?
Rgds,
Fabio
Everyone's tags (4)
CME SIP Pickup
It's working now, thanks to TAC engineer.
I open an case to help me with the question, and I have to configure:
call-park system application
On telephony-service and generate the cnf-files again (no create cnf-files, create cnf files).
Rgds,
CME SIP Pickup
Thanks for posting back, Fabio!
CME SIP Pickup
Hello Fabio,
I have a same problem, but even doing the above procedure, call pickup not working fine in the SIP Phone 3905.
This is voice register dn and pool configuration:
voice register dn  26
number XXXX
allow watch
pickup-call any-group
pickup-group 20
name MARIA
label XXXX
voice register pool  26
registration-timer max 120 min 60
id mac 203A.0723.057C
type 3905
number 1 dn 26
template 1
cor incoming LOCAL default
cor outgoing INTERNO default
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
username abcd password abcd
no vad
Do you have any other configuration to solved this problem?
Best Regards,
Cláudio Costa
CME SIP Pickup
Hi Claudio,
You have to configure the command 'call-park system application' under telephony service, and then regenerate the cnf-files.
Rgds
CME SIP Pickup
when I configuring 'call-park system application' under telephony service the pickup between Skinny Phones does
not work. Then I can use pickup from SIP Phones. (I have also activated 'fac standard' under telephony services)
When I remove the 'call-park system application', then the pickup between Skinny Phones working again.
I have testest with ios 15.3(3)M.
Is there another way to activate Pickup for SIP Phones with Pickup between Skinny Phones working ?
Carsten
Thanks ffunaki001, you saved
Thanks ffunaki001, you saved my life!! :)
4287
