CME - SIP Trunk - Nortel
Hello
All our PSTN & DID/DOD lines from provider are  terminated on Nortel CS 1000E. I need to build a SIP Trunk between CME  and Nortel PBX.
Link provided by nortel engineer is between CUCM  & Nortel, dont see any link for CME. Anyone aware then please share  the link
Here is link between CUCM & Nortel
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/523948nt.pdf
Anthony
Green
Anthony
Use this link as a reference.
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns829/795623.pdf
It may not be your exact version numbers etc
But the general info will be good
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Hi Alex
Thanks for sharing the link. The information is good in the document. I am not clear on the exact command needed to establish a SIP trunk between CME & Nortel
I see only these commands some what related to SIP
voice service voip
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
registrar server
Green
Anthony
It depends on what the CME is running
In the example quoted in the pdf the CME is running:-
SCCP phones
SIP phones
FXS as SCCP
PRI T1
For this intergration they definitely need
voice service voip
qsig decode
h323
sip
registrar server
Putting all the config in is a blanket to catch any future
devices, links that may be added.
If all your CME phones are SIP and all calls in/out are to be via SIP
dial peers then you only need to add
voice service voip
sip
registrar server
Alex
Thanks Alex.
CME---------------------SIP-Trunk------------------------Nortel
Here is the infrastructure
CME = 172.16.16.5
Nortel PBX = 172.18.18.150
There is IP reachability between both the boxes.
I dont see the sample configuration(URL you referred) any SIP configuration where it points to Nortel IP except these commands
voice service voip
qsig decode
h323
sip
registrar server
I understood the Dial-peer pointing to the Nortel IP as 'Session Target'  nothing more than this??
In Nortel I see these steps created
1) a rule created as SIP and pointing to CME IP as SIP Trunk
2) Allowed Codecs
3) negotiation allowed SIP - to - SIP
4) configuration for Dial-peer < pointing CME IP to reach extension 500 - 599 >
I am still lacking to understand the CME part for SIP
thanks
Anthony
Green
Anthony
Basically this has turned on SIP
voice service voip
sip
registrar server
The dial peer below instructs that calls using this DP are SIP
dial-peer voice 2300 voip
description dial peer digital toward Nortel SIP
translation-profile incoming voip
destination-pattern 232.
rtp payload-type cisco-codec-fax-ind 98
rtp payload-type nte 96
voice-class codec 1
voice-class sip g729 annexb-all
session protocol sipv2
session target ipv4:172.30.11.100
session transport tcp
incoming called-number ....
dtmf-relay sip-notify
fax-relay ecm disable
no vad
There is not much more to the basics
Alex
490
