CME - SIP Trunk - Outgoing calls delay
I have a Cisco 2801 directly accessing the Internet via a public IP address and it is working fine, I can make or receive calls with no problem. I then moved the 2801 inside of my local network and tried to use it the same way. The fact is I can receive calls with no problems but when I try to place and outgoing call the phone dials but wait for almost a minute with no tone or anything. Then around one minute later the call is made, I don't think this is an interdigit timeout problem given that the phone actualy dials the number.
My configuration is as follows :
Current configuration : 10012 bytes
! Last configuration change at 10:38:53 gw Wed Sep 22 2010 by cisco
version 15.1
hostname Cisco2801
boot-start-marker
boot system flash:c2801-advipservicesk9-mz.151-2.T1.bin
boot-end-marker
logging buffered 51200 warnings
enable password !lie*cri.
no aaa new-model
clock timezone gw 1 0
network-clock-participate wic 0
dot11 syslog
ip source-route
no ip dhcp use vrf connected
ip dhcp pool voix
    network 192.168.0.0 255.255.255.0
    option 150 ip 192.168.0.251
    default-router 192.168.0.251
    dns-server 212.27.54.252
ip cef
ip domain name yourdomain.com
ip name-server 10.99.0.7
ip name-server 10.99.0.8
ip name-server 10.99.0.20
ip name-server 10.99.0.50
ip name-server 194.2.0.20
no ipv6 cef
voice service voip
  ip address trusted list
   ipv4 0.0.0.0 0.0.0.0
  gcid
  no cti shutdown
  callmonitor
  allow-connections h323 to sip
  allow-connections sip to h323
  allow-connections sip to sip
  no supplementary-service sip moved-temporarily
  no supplementary-service sip refer
  sip
   registrar server expires max 120 min 60
voice iec syslog
voice register global
  mode cme
  max-dn 144
  max-pool 24
voice register session-server  1
  keepalive 60
  register-id OCT_CME
voice register session-server  2
  keepalive 60
  register-id OCT_CME2
  cti-aware
voice register dn  5
  session-server 1
voice register dn  6
  session-server 1
voice translation-rule 1
  rule 1 /.*/ /975172273/
voice translation-rule 2
  rule 1 /^.*/ /404/
voice translation-profile inclid
  translate called 2
voice translation-profile outclid
  translate calling 1
interface Loopback0
  ip address 109.69.196.138 255.255.255.255
  h323-gateway voip interface
  h323-gateway voip bind srcaddr 109.69.196.138
interface FastEthernet0/0
  description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
  ip address 192.168.0.251 255.255.255.0
  ip nat inside
  ip virtual-reassembly in
  no ip route-cache cef
  no ip route-cache
  duplex auto
  speed auto
interface FastEthernet0/1
  ip dhcp relay information policy-action drop
  ip address 10.99.80.246 255.255.0.0
  ip nat outside
  no ip route-cache
  duplex auto
  speed auto
interface BRI0/0/0
  no ip address
interface BRI0/0/1
  no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip nat inside source list 115 interface FastEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 109.69.196.137
ip route 0.0.0.0 0.0.0.0 10.99.0.207
logging esm config
access-list 115 permit ip 192.168.0.0 0.0.0.255 any
ixi transport http
  response size 64
  no shutdown
  request outstanding 1
  request timeout 60
ixi application cme
  response timeout 30
  no shutdown
voice-port 0/0/0
voice-port 0/0/1
dial-peer voice 1 voip
  translation-profile incoming inclid
  translation-profile outgoing outclid
  destination-pattern ..........
  session protocol sipv2
  session target dns:sip5.voip-centrex.net
  incoming called-number .
  codec g711ulaw
sip-ua
  credentials username mysiplogin  password 7 09051D5C414C0E081B1733 realm sip5.voip-centrex.net
  authentication username mysiplogin password 7 155B58595C63323E382802 realm sip5.voip-centrex.net
  retry register 10
  registrar dns:sip5.voip-centrex.net expires 3600
  registrar dns:sip5.voip-centrex.net expires 3600 secondary
telephony-service
  xml user infologic password infologic 15
  max-ephones 8
  max-dn 8
  ip source-address 192.168.0.251 port 2000
  auto assign 1 to 8
  load 7910 P00403020214
  load 7912 CP7912080003SCCP070409A
  load 7960-7940 P00305000301
  time-format 24
  date-format dd-mm-yy
  dialplan-pattern 1 4.. extension-length 3
  max-conferences 4 gain -6
  moh Terre.wav
  transfer-system full-consult
  log table retain-timer 30
  log table max-size 100
  create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
  session-server 1
  number 1001 no-reg primary
  name Apple Bee
  cti watch
ephone-dn  5  dual-line
  number 404
  cti watch
ephone-dn  6  dual-line
  number 405 no-reg primary
  cti watch
ephone  5
  device-security-mode none
  mac-address 0013.C353.09CD
  type 7912
  button  1:5
ephone  6
  mac-address 0013.C353.0506
  type 7912
  button  1:6
end
My 2801 is now on the 10.99.0.0 local network and access the Internet through the 109.69.196.140 ip address.
1 ACCEPTED SOLUTION
Re: CME - SIP Trunk - Outgoing calls delay
I would like to know if you already tried to use IP address if you ITSP under the sip-ua configuration instead of the FQN, just to disscard any issue with the DNS resolution taken so long.
Also I would like to see the output of the debug ccsip messsages and ccapi when doing the call.
Please rate this post if was helpful
Walter Solano
Walter Solano
Thanks for your answer, it was indeed the dns resolution taking too long, I changed the dns-server adress and everything works fine. Once again thanks for the fast answer.
Is good to hear that now everything is working
Best regards
Walter Solano.
1211
