CME SIP Trunk, single registrar multiple trunk
Hey Guys,
Please help me here, I can register single registrar and Multiple sip trunks. But the call doesnt go out without this command '
calling-info pstn-to-sip'.
I need to send different caller id which is under the two different trunks. I have tried translating but it doesnt do the job, it still tries to send the calling-info pstn-to-sip number.
Please rate the post Shibly Ibrahim
Hall of Fame Super Gold
Then remove pstn-to-sip, and use translation only.
Re: CME SIP Trunk, single registrar multiple trunk
I tried the call doesnt go out
This is my config
sip-ua
credentials username xxxxxxxxxxx password 7
xxxxxxxxxxx realm sip.voip-unlimited.net
xxxxxxxxxxx
password 7
xxxxxxxxxxx
authentication username xxxxxxxxx password 7 xxxxxxxxx realm xxx.xxxxxxx.xxx
calling-info pstn-to-sip from number set xxxxxxxxxx
retry register 10
timers register 1000
mwi-server ipv4:192.168.0.159 expires 3600 port 5060 transport udp unsolicited
registrar
xxx.xxxxxxx.xxx
expires 60
One needs to look at traces to see what happens and why.
Managed247-2911(config)#SIP/2.0 200 OK
Via: SIP/2.0/TCP 192.168.0.160:5060;branch=z9hG4bK218A2F6C
To: <2012>
Call-ID: C69A566-E6EE11E1-BACCF087-384749A6@192.168.0.160
Date: Thu, 16 Aug 2012 15:29:48 GMT
CSeq: 101 NOTIFY
Content-Length: 0
315314: Aug 16 15:29:49.112: //72745/0B18BB83BAC5/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:07728783361@91.151.2.130:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.160:5060;branch=z9hG4bK218A31BD6
From: <>08455195390@sip.voip-unlimited.net>;tag=130428EC-1A3A
To: <07728783361>
Call-ID: C69A566-E6EE11E1-BACBF087-384749A6@192.168.0.160
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1345130989
Reason: Q.850;cause=16
Content-Length: 0
315315: Aug 16 15:29:49.116: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:551BC-250E@192.168.0.68:57706;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 192.168.0.160:5060;branch=z9hG4bK218A419A8
To: <2012>
Call-ID: CEA6E3C-E6EE11E1-BACDF087-384749A6@192.168.0.160
CSeq: 101 NOTIFY
Max-Forwards: 70
Date: Thu, 16 Aug 2012 15:29:49 GMT
User-Agent: Cisco-SIPGateway/IOS-15.2.3.T1
Event: dialog
Subscription-State: active
Contact: <2012>
Content-Type: application/dialog-info+xml
Content-Length: 651
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:dialog-info" version="14" notify-state="partial" entity="sip:2012@192.168.0.160">
terminated1Tounlocked
315316: Aug 16 15:29:49.128: //72745/0B18BB83BAC5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 canceling
Via: SIP/2.0/UDP 192.168.0.160:5060;branch=z9hG4bK218A31BD6;rport=64182;received=213.249.189.234
To: <07728783361>;tag=4863a7036cb78b731105060715005165-e5f0
CSeq: 102 CANCEL
server: VOIP-UL
Content-Length: 0
315317: Aug 16 15:29:49.184: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <2012>
CSeq: 101 NOTIFY
Content-Length: 0
315318: Aug 16 15:29:49.204: //72745/0B18BB83BAC5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
Via: SIP/2.0/UDP 192.168.0.160:5060;rport=64182;received=213.249.189.234;branch=z9hG4bK218A31BD6
Record-Route: <91.151.2.130>
To: <07728783361>;tag=3554119789-193303
CSeq: 102 INVITE
Allow: INVITE, BYE, OPTIONS, CANCEL, ACK, REGISTER, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK, UPDATE, MESSAGE, PUBLISH
Contact: <07728783361>
Call-Info: <91.151.11.20>;method="NOTIFY;Event=telephone-event;Duration=1000"
Content-Length: 0
315319: Aug 16 15:29:49.204: //72745/0B18BB83BAC5/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x31943588
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 08455195390
Called Number            : 07728783361
Source IP Address (Sig  ): 192.168.0.160
Destn SIP Req Addr:Port  : 91.151.2.130:5060
Destn SIP Resp Addr:Port : 91.151.2.130:5060
Destination Name         : 91.151.2.130
315320: Aug 16 15:29:49.204: //72745/0B18BB83BAC5/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.0.160
Source IP Port    (Media): 19886
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
315321: Aug 16 15:29:49.204: //72745/0B18BB83BAC5/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 487
315322: Aug 16 15:29:49.204: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:07728783361@91.151.2.130:5060 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Allow-Events: telephone-event
Content-Length: 0
Trace is incomplete.
Ill test it after hours and send it over thanks. Can I email you by any chance.
naged247-2911#
315496: Aug 16 16:10:38.465: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:213.249.189.234:64182 SIP/2.0
Via: SIP/2.0/UDP 91.151.2.130:5060;branch=0
To: sip:213.249.189.234:64182
Call-ID: 70f18336-29b0f6c9-162188@91.151.2.130
CSeq: 1 NOTIFY
Event: keep-alive
Content-Length: 0
315497: Aug 16 16:10:38.469: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Managed247-2911#SIP/2.0 404 Not Found
To: sip:213.249.189.234:64182;tag=13298C04-2444
Date: Thu, 16 Aug 2012 16:10:38 GMT
CSeq: 1 NOTIFY
Content-Length: 0
Managed247-2911#
315498: Aug 16 16:10:41.029: //73403/C10DD77ABC20/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:07728783361@91.151.2.130:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.160:5060;branch=z9hG4bK21D0E7E8
Remote-Party-ID: <2012>;party=calling;screen=no;privacy=off
From: <>2012@sip.voip-unlimited.net>;tag=13299604-1365
To: <07728783361>
Date: Thu, 16 Aug 2012 16:10:41 GMT
Call-ID: C25EC361-E6F311E1-BC26F087-384749A6@192.168.0.160
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3238909818-3874689505-3156275335-0944196006
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1345133441
Contact: <2012>
Expires: 180
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 332
v=0
o=CiscoSystemsSIP-GW-UserAgent 9134 991 IN IP4 192.168.0.160
s=SIP Call
c=IN IP4 192.168.0.160
t=0 0
m=audio 19982 RTP/AVP 0 18 8 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
315499: Aug 16 16:10:41.029: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.0.160:5060;branch=z9hG4bK21D0F24CD
To: <2012>
Call-ID: C25EC361-E6F311E1-BC27F087-384749A6@192.168.0.160
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: dialog
Contact: <2012>
Content-Length: 648
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:dialog-info" version="30" notify-state="partial" entity="sip:2012@192.168.0.160">
trying1Tounlocked
315500: Aug 16 16:10:41.045: //73403/C10DD77ABC20/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.0.160:5060;branch=z9hG4bK21D0E7E8;rport=64182;received=213.249.189.234
To: <07728783361>
CSeq: 101 INVITE
server: VOIP-UL
Content-Length: 0
315501: Aug 16 16:10:41.045: //73403/C10DD77ABC20/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
To: <07728783361>;tag=a060b0c44d26c98b77f8f4e6919a4253.9e03
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.voip-unlimited.net", nonce="502d1b9f0000c7d8b9f6bd135ce2d63b64e1ab1b06d757e2"
server: VOIP-UL
Content-Length: 0
315502: Aug 16 16:10:41.045: //73403/C10DD77ABC20/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
315503: Aug 16 16:10:41.045: //73403/C10DD77ABC20/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.0.160:5060;branch=z9hG4bK21D10FDE
To: <07728783361>
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Contact: <2012>
Expires: 180
Proxy-Authorization: Digest username="01908793997",realm="sip.voip-unlimited.net",uri="sip:07728783361@91.151.2.130:5060",response="f8ba74073111fb9acc534155c514ad9e",nonce="502d1b9f0000c7d8b9f6bd135ce2d63b64e1ab1b06d757e2",algorithm=md5
Content-Length: 332
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
315504: Aug 16 16:10:41.061: //73403/C10DD77ABC20/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.0.160:5060;branch=z9hG4bK21D10FDE;rport=64182;received=213.249.189.234
To: <07728783361>
CSeq: 102 INVITE
server: VOIP-UL
Content-Length: 0
315505: Aug 16 16:10:41.065: //73403/C10DD77ABC20/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Spoofed From-URI Detected
To: <07728783361>;tag=a060b0c44d26c98b77f8f4e6919a4253.1046
CSeq: 102 INVITE
server: VOIP-UL
Content-Length: 0
315506: Aug 16 16:10:41.069: //73403/C10DD77ABC20/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x31973248
Calling Number           : 2012
315507: Aug 16 16:10:41.069: //73403/C10DD77ABC20/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 19982
315508: Aug 16 16:10:41.069: //73403/C10DD77ABC20/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 57
Disconnect Cause (SIP)   : 403
315509: Aug 16 16:10:41.073: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.0.160:5060;branch=z9hG4bK21D1120D1
To: <2012>
Call-ID: C2661672-E6F311E1-BC28F087-384749A6@192.168.0.160
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: dialog
Contact: <2012>
Content-Length: 652
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:dialog-info" version="31" notify-state="partial" entity="sip:2012@192.168.0.160">
Managed247-2911#rection="initiator">terminated1Tounlocked
315510: Aug 16 16:10:41.073: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Managed247-2911#
315511: Aug 16 16:10:43.169: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <2012>
Date: Thu, 16 Aug 2012 16:10:43 GMT
CSeq: 101 NOTIFY
Content-Length: 0
315512: Aug 16 16:10:43.169: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Managed247-2911#u SIP/2.0 200 OK
To: <2012>
CSeq: 101 NOTIFY
Content-Length: 0
Hey,
It worked. This was the right solution
sip-ua
credentials username xxxxxxxxxxx password 7 xxxxxxxxxxx realm xxx.xxxxxxx.xxx
retry register 10
Hello Mohamed.
I have the same problem with a UC520 (two sip trunk with the same service provider and show two different caller id).
You know if this configuration has to work with a UC520?
I've tried and not register any.
Hey Eduard
It shouldnt make any difference it should work.
For your outgoing dial-peers is the translation rule setup with an outgoing number or if you want to use a single number to call out under sip-ua type the following
or for translation rule scenario without the above
e.g. ext 2003 is calling out
you can make a rule similar to this
voice translation-rule 1
rule 1 /2003/ //
rule 2 /2002/ //
voice translation-profile Outgoing
translate calling 1
Apply the translation profile to the outgoing dial-peer. The translation rule was just an example.
The SIP provider expects a number registered with them to be seen. As long as they see anumber the call would go through. If not they will reject.
I hope I have answered your question and hope it has helped you. Sorry for the delay in answering since I didnt notice that you had replied.
Shibly
Hi Mohamed.
The problem is solved.
The operator told me (first time) that I could not show two phone numbers for the same SIP trunk, but after he said that if it was possible.
The solution was to do it through "voice-translation rules" as you tell me.
Thank you very much.
Hey Eduard,
Glad it worked. When I was trying to get it to work I faced the same issues you were facing but it was part of the learning phase.
VIP Super Bronze
Eduard,
Mohammed as provided an excellent idea to help you resolve your problem. You have implemented his suggestions and it worked perfectly for you, yet you gave him just 1 star! He has saved you alot of headache troubleshooting and going back and forth with your unco-operative ITSP, yet you gave him 1 star! No! You have to be much more appreciative than that. In this forum the only way we keep smiles on faces and continuosuly make this the best forum on the web is thorugh appreciation. learn to b thankful! Add some more stars of mark the thread as answered, because in your case it is answered.
Mohammed (+5) to you for helping Eduard out. Please contiune to share your knowledge with others.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi all and sorry Mohamed.
I put one star by mistake.
I thought it could make the stars one by one, and when I check one I could not rectify.
Sorry.
Eduard no worries. I am glad I could be of help to you.
Thanks aokanlawon I started the post having the issue and some of the replies helped me find the right answer. I am glad we've got a community to help us.
2652
