CME SIP TRUNK WITH SONUS GSX9000 HD NO REGISTER (Received : SIP/2.0 405 Method Not Allowed)
greetings to all..
i had an CME trying to connecto to a SIP trunk with provider with Sonux GSX9000 HD, the telephony provider does not support credential authentication and i can not stablish the session to stay engaged with the provider and receive the calls from PSTN.
the topology is that.
i'll provide tomorrow a visio topology to show you how is the real network.
Here is the log :
Sent:
REGISTER sip:signal.convergia.com:5060 SIP/2.0
Via: SIP/2.0/UDP 10.255.250.30:5060;branch=z9hG4bK8126F
From: <sip:099........@signal.convergia.com>;tag=705618-2183
To: <sip:099........@signal.convergia.com>
Date: Wed, 15 Jan 2014 02:03:08 GMT
Call-ID: 6F618D1-7CAF11E3-8002808A-B237480
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1389751388
CSeq: 6 REGISTER
Contact: <sip:099........@10.255.250.30:5060>
Expires:  3600
Supported: path
Content-Length: 0
Jan 15 02:03:08.551: //17/000000000000/SIP/Msg/ccsipDisplayMsg:
Received: #SIP/2.0 405 Method Not Allowed
Via: SIP/2.0/UDP 10.255.250.30:5060;branch=z9hG4bK8126F;received=200.27.121.158
CSeq: 6 REGISTER
Allow: INVITE,ACK,CANCEL,BYE,REFER,INFO,SUBSCRIBE,NOTIFY,PRACK,UPDATE,OPTIONS
Content-Length: 0
Here are the relevant configurations.
voice service voip
ip address trusted list
  ipv4 172.30.253.253 255.255.255.255
  ipv4 200.75.6.66 255.255.255.255
  ipv4 200.75.6.67 255.255.255.255
  ipv4 200.27.121.158 255.255.255.255
dtmf-interworking standard
media transcoder sync-streams
media anti-trombone
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip handle-replaces
no fax-relay sg3-to-g3
h323
  ip circuit max-calls 40960
  no h225 timeout keepalive
  no call service stop
  call start slow
  session transport udp
  modem passthrough nse codec g711ulaw
sip
  bind control source-interface FastEthernet0/1
  bind media source-interface FastEthernet0/1
  registrar server expires max 120 min 60
  localhost dns:signal.convergia.com
  no update-callerid
  g729 annexb-all
sip-ua
no remote-party-id
retry invite 10
retry response 10
retry bye 2
retry cancel 2
retry register 10
retry options 5
timers connect 100
timers register 250
registrar 1 dns:signal.convergia.com expires 3600 refresh-ratio 50
sip-server dns:signal.convergia.com
host-registrar
permit hostname dns:media.convergia.com
permit hostname dns:signal.convergia.com
dial-peer voice 10000 voip
description CONVERGIA-SIP-OUTGOING
translation-profile outgoing PSTN_Outgoing
destination-pattern .
session protocol sipv2
session target sip-server
voice-class codec 2
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 10001000 pots
description OUTGOING_VOICE_DIAL-PEER.CELL.PSTN
destination-pattern 099........
port 0/2/0
forward-digits 8
voice translation-profile PSTN_Outgoing
translate calling 10
translate called 20
voice translation-rule 10
rule 1 /^.*/ /227602276/
voice translation-rule 20
rule 1 /\(.*\)/ /56227602276/
voice class codec 2
codec preference 1 g729r8
Hope you could help me .
had a great day . best regards, and rate if you'll find this post useful
  • IP Telephony
Re: CME SIP TRUNK WITH SONUS GSX9000 HD NO REGISTER (Received :
Your ISP only allow the following header you will need to remove the register part from the SIP message:
Content-Length: 0
Voice CCIE #37771
Thanks Hermanus for your answer.
I just want to confirm... you say i must put this commands on VoGW ?
sip-ua
no host-registrar
I'll try and i let you know...
best regards.
i'll modify all sip headers to conform what the TISP requires.
voice class sip-profiles 1
request REGISTER sip-header Via modify "10.255.250.30:5060" "200.27.121.158:5060"
request REGISTER sip-header Contact modify "<>" "<56227602276>"
request REGISTER sip-header From modify "<>" "<56227602276>"
request REGISTER sip-header To modify "@(.*)>" "@200.75.6.67>"
to change from this
Sent:
Via: SIP/2.0/UDP 10.255.250.30:5060;branch=z9hG4bK251E4F
To: <099........>
Date: Wed, 15 Jan 2014 14:57:16 GMT
Call-ID: 1DA2B6CB-7D2C11E3-8021808A-B237480
Max-Forwards: 70
Timestamp: 1389797836
CSeq: 2 REGISTER
Contact: <099........>
Expires:  3600
Supported: path
Content-Length: 0
Received:
To: <099........>
CSeq: 2 REGISTER
Content-Length: 0
to this
Sent:
REGISTER sip:200.75.6.67:5060 SIP/2.0
Via: SIP/2.0/UDP 200.27.121.158:5060;branch=z9hG4bK4B132B
To: <099........>
Date: Wed, 15 Jan 2014 16:53:19 GMT
Call-ID: 5EAE36EC-7D3C11E3-8089808A-B237480
Max-Forwards: 70
Timestamp: 1389804799
CSeq: 2 REGISTER
Contact: <56227602276>
Expires:  3600
Supported: path
Content-Length: 0
Received:
To: <099........>
CSeq: 2 REGISTER
Content-Length: 0
now the TISP accept the calling, but there is another weird behavior... the call never complettes from the CUCME side, The VoIPGW send an error
Jan 15 16:46:17.962: %VOICE_IEC-3-GW: H323: Internal Error (TCS ack wait timeout): IEC=1.1.183.5.63.0 on callID 116 GUID=59A00FCC7D3B11E398E5FC9A981BD0D7
Jan 15 16:46:17.962: //116/59A00FCC98E5/CCAPI/cc_api_call_disconnected:
   Cause Value=41, Interface=0x6966DD14, Call Id=116
   Call Entry(Responsed=TRUE, Cause Value=41, Retry Count=0)
Jan 15 16:46:17.962: //116/59A00FCC98E5/CCAPI/ccConferenceDestroy:
   Conference Id=0x3, Tag=0x0
Jan 15 16:46:17.966: //116/59A00FCC98E5/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x3, Source Interface=0x6966DD14, Source Call Id=116,
   Destination Call Id=117, Disposition=0x0, Tag=0x0
Jan 15 16:46:17.966: //117/59A00FCC98E5/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x3, Source Interface=0x697A9E78, Source Call Id=117,
   Destination Call Id=116, Disposition=0x0, Tag=0x0
Jan 15 16:46:17.966: //116/59A00FCC98E5/CCAPI/cc_generic_bridge_done:
Jan 15 16:46:17.966: //116/59A00FCC98E5/CCAPI/ccCallDisconnect:
   Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=41)
   Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
Jan 15 16:46:17.966: //116/59A00FCC98E5/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jan 15 16:46:17.966: //117/59A00FCC98E5/CCAPI/ccCallDisconnect:
   Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
anyone know why happen that ?
i currently had in the CUCME an FXO port and when i call to another number the dialpeer sents me thru that port and i had a call without any problem,
only the problem appears when i try to get communication thru the SIP trunk.
thanks for your time.
can we see debug voice ccsip for this new strange behavior.
It is good news to see the ISP accepts your SIP request now.
Voice CCIE #37771
here is the debug ccsip all trace log.
i can see in log some stuff but can't understand it at all ...
690
