CME SIP trunk
Our customer has 2821 with CME and SCCP IP Phones. For external calls they use SIP trunk.
There is a requirement of the SIP provider that the prefix 11111# should be prepended to all calls. I know how to do it. That
s not a problem. But I stuck with another one.
For example, we are placing a call to 92222222 – we translating this number to 11111#74952222222 as SIP provider required.
On the phone display we can see called number "92222222"
On the other side somebody answers the call.
In this moment called number changes from "92222222" to 11111#74952222222 if IOS version 12.4.25b and to 11111 if IOS version 12.4.24T2
But I want to keep the number "92222222".
How can I fix this.
voice translation-rule 1
  rule 1 /^8/ /11111#7/
  rule 2 /^9/ /11111#7495/
voice translation-profile 1
  translate calling 2
dial-peer voice 101 voip
  translation-profile outgoing 1
  destination-pattern 8..........
  session protocol sipv2
  session target ipv4:195.x.x.1
  dtmf-relay rtp-nte
  codec g711alaw
  no vad
dial-peer voice 102 voip
  destination-pattern 9.......
  dtmf-relay rtp-nte
  codec g711alaw
  no vad
dial-peer voice 103 voip
  destination-pattern 810T
  dtmf-relay rtp-nte
  codec g711alaw
  no vad
telephony-service
  max-ephones 96
  max-dn 288
  ip source-address 172.20.6.10 port 2000
auto assign 1 to 25
  system message Enigma
  sdspfarm units 5
  sdspfarm transcode sessions 10
  sdspfarm tag 1 mtp001cf6b3c550
  network-locale RU
  time-zone 32
  time-format 24
  date-format dd-mm-yy
  create cnf-files version-stamp 7960 Dec 07 2009 17:15:36
  dialplan-pattern 1 1... extension-length 4
  max-conferences 8 gain -6
  call-forward pattern .T
  moh flash:music-on-hold.au
  web admin system name cmeadmin secret 5 $1$N.78$cTZu7ryFw8Krahn1GoX.J/
  dn-webedit
  time-webedit
  transfer-system full-consult
transfer-pattern .T
Everyone's tags (4)
Hall of Fame Super Gold
Re: CME SIP trunk
I may be wrong, but I don't think it can be done.
CME is correctly presenting the number that you're connected to.
Ask ITSP to remove the prefix requirement.
Re: CME SIP trunk
Thanks for reply
As I said we have different behaviour
Called number changes from "92222222" to 11111#74952222222 if IOS version 12.4.25b and to 11111 if IOS version 12.4.24T2
Re: CME SIP trunk
Likely IOS bug in 12.4T
Re: CME SIP trunk
my solution - use sip-profiles instead of translation-profiles
voice class sip-profiles 101
  request ANY sip-header SIP-Req-URI modify "(sip:)(8)(.*@)" "\111111%237\3"
    voice-class sip profiles 101
    dtmf-relay rtp-nte
    codec g711alaw
    no vad
Re: CME SIP trunk
interesting one
1725
