CME - SNR Issue
HI
I am trying to setup SNR on in my CME lad i have found the configuration on the www but the commands it wants me to use are
mobility
snr 1004 delay 5 timeout 15 cfwd-noan 1001
neither mobility or snr are options under the ephone-dn
I am using the full 8.0 cme.
Any help would be appreciative
Nathan
Everyone's tags (4)
1 ACCEPTED SOLUTION
Green
CME - SNR Issue
Nathan
Version 3.4(0)
Cisco CallManager Express
Yes you need to upgrade to at least CME Ver 7.1 to enable SNR-Mobility
Use this site to find the IOS etc you need
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Green
CME - SNR Issue
Nathan,
My lab CME is 7.1 on an 1861.
SNR commands are all good.
Yours is CME 8.0
What IOS are you using.
Alex
CME - SNR Issue
HI,
Im using
flash:c3845-ipvoicek9-mz.124-6.XT2.bin"
Nathan
Green
CME - SNR Issue
Nathan,
Can you post thye output from
show telephony
Alex
CME - SNR Issue
Router#sho telephony
CONFIG [Version=3.4(0)]
Version 3.4(0)
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 3.3.3.1 port 2000
load 7905 SCCP70.8-5-3S.loads
load 7912 SCCP70.8-5-3S.loads
max-ephones 30
max-dn 30
max-conferences 12 gain -6
dspfarm units 0
dspfarm transcode sessions 0
hunt-group report delay 1 hours
max-redirect 5
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
keepalive 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
caller-id name-only: enable
web admin system name Admin
web admin customer name Customer
edit DN through Web:  disabled.
edit TIME through web:  disabled.
Log (table parameters):
     max-size: 150
     retain-timer: 15
local directory service: enabled.
I think this is using cme 3.4 but using the cme 8.0 files, but im not too sure.
Green
CME - SNR Issue
Nathan
Version 3.4(0)
Alex
CME - SNR Issue
Do you know what i think this is, I started using ccp just to see if this was any good and i enabled cucmbe but it only enabled 3.4 but this was after i uploaded all the cme 8.0.
Is this IOS ok for cme and snr then?
Note to self - Don't use CCP again, stick with cli
Thanks for all your help
640
