10-30-2010 09:47 AM - edited 03-16-2019 01:38 AM
I need to configure voice Gateway as SRST. My concern is how to apply call privileges. For sure I have to use CoR. I am planning to configure the router as the following:
telephony-service
srst mode auto-provision dn
srst dn line-mode octo
max-ephones [the number of the phones in the site]
max-dn [the number of DNs]
ip source-address 10.30.20.254 port 2000
ephone-dn 1
number 1000
corlist incoming local
But I have the following questions;
1- Shall I configure the ephones or just ephone-dn it will be very difficult to add all mac-addresses.
2- Shall I add the SRST configuration in CME\SRST mode or the configuration under the telephony services is enough? And again I need to use the cor configuration under fallback configuration?
10-31-2010 06:19 AM
Is it very complicated ???
10-31-2010 06:36 AM
Hi JFV,
This doc shows an excellent config example for Class of Restriction
for SRST;
Cheers!
Rob
10-31-2010 09:42 AM
Thank you Rob,
but actually I need it for CME as SRST not gateway configured as SRST
11-02-2010 07:08 AM
The concepts carry over, whether it be a plain gateway with dial-peers, CME, SRST, or CME-SRST.
The concepts are documents here:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
The only difference is where the CORlist on the IP phone leg is applied. With SRST, the CORs for the 'dial-peers' on the IP phone are configured under:
call-manager-fallback
corlist [incoming|outgoing]
For CME/CME-SRST, it's done under the DN:
ephone-dn 1
