02-23-2014 07:12 AM - edited 03-16-2019 09:52 PM
I have cucm 9 and cme 9 with srst on remote site.
I have configured snr (mobility) and it was working fine.
I have configured dial-peer hunt because I get a busy tone when the cucm is available and all phone are registered to the cucm instead of the cme.
Now snr do not work anymore do you have an idea ?
Thank you
02-23-2014 08:55 AM
Hi boub91,
Was this setup working before?
The problem is not completely clear. Do you mean that the IP Phones' SNR is no longer working AFTER they are registered to the CUCM? Or does it not work when they are in SRST?
What is the dial-peer hunt that you are referring to in the configuration?
Sree
02-24-2014 12:21 AM
Hi Sreekanth Narayanan,
SNR was working fine when all phone are registered on cucm and on cme if cucm is not available.
CME is connected to PSTN with an E1 to receive incoming call.
I have an issue when all phone are registered to the cucm and incoming call (from pstn) didn't work because we get a busy tone instead of ringing the phone that are registered to CUCM. I used the command "dial-peer hunt", configure "preference 1" for all dial-peer voip and "preference 8" for all ephone-dn to resolve this issue.
But now I have a new issue SNR do not work anymore, if I remove the command "dial-peer hunt" SNR work immediatly.
I have to put the command "dial-peer hunt" again to receive incoming call from pstn to all phone registered to the cucm.
Thank you
02-24-2014 02:52 AM
Hi ,
Can you send across "debug voice ccapi inout" logs from the gateway , when you use SNR.
02-24-2014 05:57 AM
With the dial-peer hunt configured on the cme :
* snr do not work if all phone are registered to the cme
* snr work if all phone are registered to the cucm
these is the log file (ccapi inout)
02-24-2014 06:04 AM
Log file SNR working without "dial-peer hunt"
phone number 1001 call phone number 7139
*Feb 24 13:45:40.363: //-1/C875413D8049/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Feb 24 13:45:40.363: //-1/C875413D8049/CCAPI/cc_api_call_setup_ind_common:
Interface=0x3EA8ABC0, Call Info(
Calling Number=1001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20009, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Feb 24 13:45:40.363: //-1/C875413D8049/CCAPI/ccCheckClipClir:
In: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Feb 24 13:45:40.363: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 24 13:45:40.363: :cc_get_feature_vsa malloc success
*Feb 24 13:45:40.363: cc_get_feature_vsa count is 1
*Feb 24 13:45:40.363: :FEATURE_VSA attributes are: feature_name:0,feature_time:1015700712,feature_id:38
*Feb 24 13:45:40.363: //43/C875413D8049/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
*Feb 24 13:45:40.363: //43/C875413D8049/CCAPI/cc_process_call_setup_ind:
Event=0x22B8ED30
*Feb 24 13:45:40.363: //43/C875413D8049/CCAPI/ccCallSetContext:
Context=0x21044D50
>>>>CCAPI handed cid 43 with tag 20009 to app "_ManagedAppProcess_Default"
*Feb 24 13:45:40.363: //43/C875413D8049/CCAPI/ccCallSetupAck:
Call Id=43
*Feb 24 13:45:40.363: //43/C875413D8049/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
*Feb 24 13:45:40.363: //43/C875413D8049/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=43
*Feb 24 13:45:40.363: //43/C875413D8049/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
*Feb 24 13:45:40.363: //43/C875413D8049/CCAPI/ccCallReportDigits:
(callID=0x2B, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=43
*Feb 24 13:45:40.363: //43/C875413D8049/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x3EA8ABC0, callID=0x2B, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x3EA8ABC0, Call Id=43
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
*Feb 24 13:45:40.563: //43/C875413D8049/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=43, Digit=7, DigitBeginFlags=0x0,
Rtp Timestamp=0x222630, Rtp Expiration=0x0
*Feb 24 13:45:40.563: //43/C875413D8049/CCAPI/cc_api_call_digit_end:
Source Call Id=43, Digit=7, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
*Feb 24 13:45:40.763: //43/C875413D8049/CCAPI/cc_api_call_digit_begin:
Source Call Id=43, Digit=1, DigitBeginFlags=0x0,
Rtp Timestamp=0x22A330, Rtp Expiration=0x0
*Feb 24 13:45:40.763: //43/C875413D8049/CCAPI/cc_api_call_digit_end:
Source Call Id=43, Digit=1, Duration=100,
*Feb 24 13:45:40.963: //43/C875413D8049/CCAPI/cc_api_call_digit_begin:
Source Call Id=43, Digit=3, DigitBeginFlags=0x0,
Rtp Timestamp=0x232030, Rtp Expiration=0x0
*Feb 24 13:45:40.963: //43/C875413D8049/CCAPI/cc_api_call_digit_end:
Source Call Id=43, Digit=3, Duration=100,
*Feb 24 13:45:41.163: //43/C875413D8049/CCAPI/cc_api_call_digit_begin:
Source Call Id=43, Digit=9, DigitBeginFlags=0x0,
Rtp Timestamp=0x239D30, Rtp Expiration=0x0
*Feb 24 13:45:41.163: //43/C875413D8049/CCAPI/cc_api_call_digit_end:
Source Call Id=43, Digit=9, Duration=100,
*Feb 24 13:45:41.163: //43/C875413D8049/CCAPI/ccCallReportDigits:
(callID=0x2B, digit_event=0x0, enable=FALSE, consume=FALSE)
*Feb 24 13:45:41.163: //43/C875413D8049/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x3EA8ABC0, callID=0x2B, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Feb 24 13:45:41.163: //43/C875413D8049/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
*Feb 24 13:45:41.163: //43/C875413D8049/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=20007, Params=0x21047690, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Feb 24 13:45:41.163: //43/C875413D8049/CCAPI/ccCheckClipClir:
Destination Pattern=7139$, Called Number=7139, Digit Strip=TRUE
Called Number=7139(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Gardien
Account Number=, Final Destination Flag=FALSE,
Guid=C875413D-9C90-11E3-8049-CEBF22E24994, Outgoing Dial-peer=20007
*Feb 24 13:45:41.167: //43/C875413D8049/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=7139
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
*Feb 24 13:45:41.167: //43/C875413D8049/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x234EC5BC, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=1001,(Calling Name=Gardien )(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=7139(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=20007, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Feb 24 13:45:41.167: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 24 13:45:41.167: :cc_get_feature_vsa malloc success
*Feb 24 13:45:41.167: cc_get_feature_vsa count is 2
*Feb 24 13:45:41.167: :FEATURE_VSA attributes are: feature_name:0,feature_time:1015700488,feature_id:39
*Feb 24 13:45:41.167: //44/C875413D8049/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Feb 24 13:45:41.167: //44/C875413D8049/CCAPI/ccCallSetContext:
Context=0x21047640
*Feb 24 13:45:41.167: //43/C875413D8049/CCAPI/ccSaveDialpeerTag:
*Feb 24 13:45:41.167: //44/C875413D8049/CCAPI/cc_api_set_ssCTreRoutingNotSupported:
CallInfo(ssCTreRoutingNotSupported=TRUE)
*Feb 24 13:45:41.171: //44/C875413D8049/CCAPI/cc_api_update_call_info:
Interface=0x234EC5BC, Call Id=0x2C
*Feb 24 13:45:41.171: //44/C875413D8049/CCAPI/cc_api_call_proceeding:
Interface=0x234EC5BC, Progress Indication=NULL(0)
*Feb 24 13:45:41.175: //44/C875413D8049/CCAPI/cc_api_call_alert:
Interface=0x234EC5BC, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Call Entry(Retry Count=0, Responsed=TRUE)
*Feb 24 13:45:41.175: //43/C875413D8049/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
*Feb 24 13:45:41.175: //43/C875413D8049/CCAPI/ccSaveDialpeerTag:
phone number 7139 ring
*Feb 24 13:45:46.163: //43/C875413D8049/CCAPI/ccSaveDialpeerTag:
Outgoing Dial-peer=0
*Feb 24 13:45:46.163: //43/C875413D8049/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=100, Params=0x21049F80, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Feb 24 13:45:46.163: //43/C875413D8049/CCAPI/ccCheckClipClir:
In: Calling Number=0237917149(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=0237917149(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Destination Pattern=0T, Called Number=00603895353, Digit Strip=TRUE
Calling Number=0237917149(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=00603895353(TON=Unknown, NPI=Unknown),
Guid=C875413D-9C90-11E3-8049-CEBF22E24994, Outgoing Dial-peer=100
*Feb 24 13:45:46.163: //43/C875413D8049/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=0237917149
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=00603895353
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
*Feb 24 13:45:46.163: //43/C875413D8049/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x22F1E390, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=0237917149,(Calling Name=Gardien )(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=00603895353(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=100, Call Count On=FALSE,
*Feb 24 13:45:46.163: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 24 13:45:46.163: :cc_get_feature_vsa malloc success
*Feb 24 13:45:46.163: cc_get_feature_vsa count is 3
*Feb 24 13:45:46.163: :FEATURE_VSA attributes are: feature_name:0,feature_time:1015700040,feature_id:40
*Feb 24 13:45:46.163: //45/C875413D8049/CCAPI/ccIFCallSetupRequestPrivate:
*Feb 24 13:45:46.163: //45/C875413D8049/CCAPI/ccCallSetContext:
Context=0x21049F30
*Feb 24 13:45:46.163: //45/C875413D8049/CCAPI/cc_api_set_ssCTreRoutingNotSupported:
*Feb 24 13:45:46.223: //45/C875413D8049/CCAPI/cc_api_call_proceeding:
Interface=0x22F1E390, Progress Indication=NULL(0)
*Feb 24 13:45:46.227: //45/C875413D8049/CCAPI/cc_api_call_alert:
Interface=0x22F1E390, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
*Feb 24 13:45:46.227: //43/C875413D8049/CCAPI/ccCallAlert:
*Feb 24 13:45:46.227: //43/C875413D8049/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x2B, gcid=C875413D-9C9011E3-8049CEBF-22E24994, tag=0x0)
*Feb 24 13:45:46.227: //45/C875413D8049/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x2D, gcid=C875413D-9C9011E3-8049CEBF-22E24994, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=43, Call Id2=45, Tag=0x0
*Feb 24 13:45:46.227: //43/C875413D8049/CCAPI/cc_api_bridge_done:
Conference Id=0xD, Source Interface=0x3EA8ABC0, Source Call Id=43,
Destination Call Id=45, Disposition=0x0, Tag=0xFFFFFFFF
*Feb 24 13:45:46.227: //45/C875413D8049/CCAPI/cc_api_bridge_done:
Conference Id=0xD, Source Interface=0x22F1E390, Source Call Id=45,
Destination Call Id=43, Disposition=0x0, Tag=0xFFFFFFFF
*Feb 24 13:45:46.227: //43/C875413D8049/CCAPI/cc_generic_bridge_done:
*Feb 24 13:45:46.231: //43/C875413D8049/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0xD, Destination Call Id=45)
*Feb 24 13:45:46.231: //45/C875413D8049/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0xD, Destination Call Id=43)
*Feb 24 13:45:46.231: confID:0xD; callEntry1 callID1:0x2B, type:6; callEntry2 callID2:0x2D, type:6
*Feb 24 13:45:46.231: //43/C875413D8049/CCAPI/cc_api_caps_ind:
Destination Interface=0x22F1E390, Destination Call Id=45, Source Call Id=43,
Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=160, Signal Type=2)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
*Feb 24 13:45:46.231: //45/C875413D8049/CCAPI/cc_api_caps_ind:
Destination Interface=0x3EA8ABC0, Destination Call Id=43, Source Call Id=45,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
*Feb 24 13:45:46.231: //45/C875413D8049/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6391)
*Feb 24 13:45:46.231: //43/C875413D8049/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Fax Version:=0, Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6323)
*Feb 24 13:45:46.231: //43/C875413D8049/CCAPI/cc_process_notify_bridge_done:
Conference Id=0xD, Call Id1=43, Call Id2=45
*Feb 24 13:45:46.231: //43/C875413D8049/CCAPI/cc_api_voice_mode_event:
Call Id=43
Call Entry(Context=0x21044D50)
*Feb 24 13:45:46.231: //45/C875413D8049/CCAPI/cc_api_voice_mode_event:
Call Id=45
Call Entry(Context=0x21049F30)
mobile phone ring
*Feb 24 13:45:50.195: //44/C875413D8049/CCAPI/cc_api_call_connected:
Interface=0x234EC5BC, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
mobile phone take the call
*Feb 24 13:46:13.895: //45/C875413D8049/CCAPI/cc_api_call_connected:
Interface=0x22F1E390, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
*Feb 24 13:46:13.895: //43/C875413D8049/CCAPI/ccCallConnect:
Progress Indication=INBAND(8), Data Bitmask=0x0
Call Entry(Connected=TRUE, Responsed=TRUE)
*Feb 24 13:46:13.899: //43/C875413D8049/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
phone number 7139 get the call (resume)
*Feb 24 13:46:29.335: //44/C875413D8049/CCAPI/cc_api_call_facility:
Interface=0x234EC5BC, Call Id=44
*Feb 24 13:46:29.335: //43/C875413D8049/CCAPI/ccConferenceDestroy:
Conference Id=0xD, Tag=0x0
*Feb 24 13:46:29.335: confID:0xD; callEntry1 callID1:0x2B, type:6; callEntry2 callID2:0x2D, type:6
*Feb 24 13:46:29.339: //43/C875413D8049/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=45, Disposition=0x0, Tag=0x0
*Feb 24 13:46:29.339: //45/C875413D8049/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=43, Disposition=0x0, Tag=0x0
*Feb 24 13:46:29.339: //43/C875413D8049/CCAPI/cc_generic_bridge_done:
*Feb 24 13:46:29.339: //45/C875413D8049/CCAPI/ccCallFacility:
Call Id=45
*Feb 24 13:46:29.339: //43/C875413D8049/CCAPI/ccGenerateToneInfo:
*Feb 24 13:46:29.339: //45/C875413D8049/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Feb 24 13:46:29.339: //45/C875413D8049/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
*Feb 24 13:46:29.339: //43/C875413D8049/CCAPI/ccConferenceCreate:
*Feb 24 13:46:29.339: //44/C875413D8049/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x2C, gcid=C875413D-9C9011E3-8049CEBF-22E24994, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=43, Call Id2=44, Tag=0x0
*Feb 24 13:46:29.339: //43/C875413D8049/CCAPI/cc_api_bridge_done:
Conference Id=0xE, Source Interface=0x3EA8ABC0, Source Call Id=43,
Destination Call Id=44, Disposition=0x0, Tag=0xFFFFFFFF
*Feb 24 13:46:29.339: //44/C875413D8049/CCAPI/cc_api_bridge_done:
Conference Id=0xE, Source Interface=0x234EC5BC, Source Call Id=44,
Call Entry(Conference Id=0xE, Destination Call Id=44)
Call Entry(Conference Id=0xE, Destination Call Id=43)
*Feb 24 13:46:29.339: confID:0xE; callEntry1 callID1:0x2B, type:6; callEntry2 callID2:0x2C, type:6
*Feb 24 13:46:29.339: //43/C875413D8049/CCAPI/cc_api_caps_ind:
Destination Interface=0x234EC5BC, Destination Call Id=44, Source Call Id=43,
*Feb 24 13:46:29.339: //44/C875413D8049/CCAPI/cc_api_caps_ind:
Destination Interface=0x3EA8ABC0, Destination Call Id=43, Source Call Id=44,
*Feb 24 13:46:29.339: //44/C875413D8049/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1262)
*Feb 24 13:46:29.339: //43/C875413D8049/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5790)
*Feb 24 13:46:29.339: //43/C875413D8049/CCAPI/ccCallFeature:
Feature Type=25, Call Id=43
*Feb 24 13:46:29.343: //44/C875413D8049/CCAPI/ccCallFeature:
Feature Type=25, Call Id=44
*Feb 24 13:46:29.343: //44/C875413D8049/CCAPI/cc_api_voice_mode_event:
Call Id=44
Call Entry(Context=0x21047640)
*Feb 24 13:46:29.343: //43/C875413D8049/CCAPI/cc_api_voice_mode_event:
Call Id=43
*Feb 24 13:46:29.343: //43/C875413D8049/CCAPI/cc_process_notify_bridge_done:
Conference Id=0xE, Call Id1=43, Call Id2=44
*Feb 24 13:46:29.371: //45/C875413D8049/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x22F1E390, Tag=0x0, Call Id=45,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*Feb 24 13:46:29.371: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb 24 13:46:29.371: :cc_free_feature_vsa freeing 3C8A5A40
*Feb 24 13:46:29.371: vsacount in free is 2
phone number 7139 end call
*Feb 24 13:46:41.847: //44/C875413D8049/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x234EC5BC, Call Id=44
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*Feb 24 13:46:41.847: //43/C875413D8049/CCAPI/ccConferenceDestroy:
Conference Id=0xE, Tag=0x0
*Feb 24 13:46:41.847: confID:0xE; callEntry1 callID1:0x2B, type:6; callEntry2 callID2:0x2C, type:6
*Feb 24 13:46:41.847: //43/C875413D8049/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=44, Disposition=0x0, Tag=0x0
*Feb 24 13:46:41.847: //44/C875413D8049/CCAPI/cc_api_bridge_drop_done:
*Feb 24 13:46:41.847: //43/C875413D8049/CCAPI/cc_generic_bridge_done:
*Feb 24 13:46:41.847: //43/C875413D8049/CCAPI/ccCallDisconnect:
*Feb 24 13:46:41.847: //43/C875413D8049/CCAPI/cc_api_get_transfer_info:
*Feb 24 13:46:41.847: //44/C875413D8049/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
*Feb 24 13:46:41.847: //44/C875413D8049/CCAPI/cc_api_get_transfer_info:
*Feb 24 13:46:41.851: //44/C875413D8049/CCAPI/cc_api_call_feature:
Feature Type=6, Interface=0x234EC5BC, Call Id=44
*Feb 24 13:46:41.851: //43/C875413D8049/CCAPI/cc_api_call_feature:
Feature Type=6, Interface=0x3EA8ABC0, Call Id=43
*Feb 24 13:46:41.851: //44/C875413D8049/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234EC5BC, Tag=0x0, Call Id=44,
*Feb 24 13:46:41.855: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb 24 13:46:41.855: :cc_free_feature_vsa freeing 3C8A5C00
*Feb 24 13:46:41.855: vsacount in free is 1
*Feb 24 13:46:41.855: //43/C875413D8049/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3EA8ABC0, Tag=0x0, Call Id=43,
*Feb 24 13:46:41.855: :cc_free_feature_vsa freeing 3C8A5CE0
*Feb 24 13:46:41.855: vsacount in free is 0
02-24-2014 06:09 AM
Log file SNR not working with "dial-peer hunt"
phone number 7139 ring but not the mobile phone
*Feb 24 13:35:16.995: //-1/54E7758E802B/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
*Feb 24 13:35:16.999: //-1/54E7758E802B/CCAPI/cc_api_call_setup_ind_common:
*Feb 24 13:35:16.999: //-1/54E7758E802B/CCAPI/ccCheckClipClir:
*Feb 24 13:35:16.999: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 24 13:35:16.999: :cc_get_feature_vsa malloc success
*Feb 24 13:35:16.999: cc_get_feature_vsa count is 1
*Feb 24 13:35:16.999: :FEATURE_VSA attributes are: feature_name:0,feature_time:1015700040,feature_id:23
*Feb 24 13:35:16.999: //20/54E7758E802B/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Feb 24 13:35:16.999: //20/54E7758E802B/CCAPI/cc_process_call_setup_ind:
Event=0x22B8ED30
*Feb 24 13:35:16.999: //20/54E7758E802B/CCAPI/ccCallSetContext:
Context=0x2104C820
>>>>CCAPI handed cid 20 with tag 20009 to app "_ManagedAppProcess_Default"
*Feb 24 13:35:16.999: //20/54E7758E802B/CCAPI/ccCallSetupAck:
Call Id=20
*Feb 24 13:35:16.999: //20/54E7758E802B/CCAPI/cc_api_set_transfer_info:
*Feb 24 13:35:16.999: //20/54E7758E802B/CCAPI/ccGenerateToneInfo:
Tone Direction=Network, Params=0x0, Call Id=20
*Feb 24 13:35:16.999: //20/54E7758E802B/CCAPI/ccSetDigitTimeouts:
*Feb 24 13:35:16.999: //20/54E7758E802B/CCAPI/ccCallReportDigits:
(callID=0x14, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=20
*Feb 24 13:35:16.999: //20/54E7758E802B/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x3EA8ABC0, callID=0x14, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x3EA8ABC0, Call Id=20
*Feb 24 13:35:17.199: //20/54E7758E802B/CCAPI/cc_api_call_digit_begin:
Source Call Id=20, Digit=7, DigitBeginFlags=0x0,
Rtp Timestamp=0x183B20, Rtp Expiration=0x0
*Feb 24 13:35:17.199: //20/54E7758E802B/CCAPI/cc_api_call_digit_end:
Source Call Id=20, Digit=7, Duration=100,
*Feb 24 13:35:17.399: //20/54E7758E802B/CCAPI/cc_api_call_digit_begin:
Source Call Id=20, Digit=1, DigitBeginFlags=0x0,
Rtp Timestamp=0x18B820, Rtp Expiration=0x0
*Feb 24 13:35:17.399: //20/54E7758E802B/CCAPI/cc_api_call_digit_end:
Source Call Id=20, Digit=1, Duration=100,
*Feb 24 13:35:17.599: //20/54E7758E802B/CCAPI/cc_api_call_digit_begin:
Source Call Id=20, Digit=3, DigitBeginFlags=0x0,
Rtp Timestamp=0x193520, Rtp Expiration=0x0
*Feb 24 13:35:17.599: //20/54E7758E802B/CCAPI/cc_api_call_digit_end:
Source Call Id=20, Digit=3, Duration=100,
*Feb 24 13:35:17.799: //20/54E7758E802B/CCAPI/cc_api_call_digit_begin:
Source Call Id=20, Digit=9, DigitBeginFlags=0x0,
Rtp Timestamp=0x19B220, Rtp Expiration=0x0
*Feb 24 13:35:17.799: //20/54E7758E802B/CCAPI/cc_api_call_digit_end:
Source Call Id=20, Digit=9, Duration=100,
*Feb 24 13:35:17.799: //20/54E7758E802B/CCAPI/ccCallReportDigits:
(callID=0x14, digit_event=0x0, enable=FALSE, consume=FALSE)
*Feb 24 13:35:17.799: //20/54E7758E802B/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x3EA8ABC0, callID=0x14, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Feb 24 13:35:17.799: //20/54E7758E802B/CCAPI/ccCallProceeding:
*Feb 24 13:35:17.799: //20/54E7758E802B/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=7, Params=0x2104DCE8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Feb 24 13:35:17.799: //20/54E7758E802B/CCAPI/ccCheckClipClir:
Destination Pattern=7..., Called Number=7139, Digit Strip=FALSE
*Feb 24 13:35:17.803: //20/54E7758E802B/CCAPI/ccCallSetupRequest:
Guid=54E7758E-9C8F-11E3-802B-CEBF22E24994, Outgoing Dial-peer=7
*Feb 24 13:35:17.803: //20/54E7758E802B/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=7139
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
*Feb 24 13:35:17.803: //20/54E7758E802B/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3D835BF0, Interface Type=1, Destination=, Mode=0x0,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=7, Call Count On=FALSE,
*Feb 24 13:35:17.803: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 24 13:35:17.803: :cc_get_feature_vsa malloc success
*Feb 24 13:35:17.803: cc_get_feature_vsa count is 2
*Feb 24 13:35:17.803: :FEATURE_VSA attributes are: feature_name:0,feature_time:1015700488,feature_id:24
*Feb 24 13:35:17.803: //21/54E7758E802B/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Feb 24 13:35:17.803: //21/54E7758E802B/CCAPI/ccCallSetContext:
Context=0x2104DC98
*Feb 24 13:35:17.803: //20/54E7758E802B/CCAPI/ccSaveDialpeerTag:
*Feb 24 13:35:17.803: //21/54E7758E802B/CCAPI/ccGetMediaClassTag:
media class tag 0
*Feb 24 13:35:17.803: //21/54E7758E802B/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
*Feb 24 13:35:17.803: //20/54E7758E802B/CCAPI/ccSetMediaclassIp2ipTags:
*Feb 24 13:35:17.803: //21/54E7758E802B/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
*Feb 24 13:35:17.803: //20/54E7758E802B/CCAPI/ccGet_xc_nr_asp_info:
*Feb 24 13:35:20.803: //21/54E7758E802B/CCAPI/cc_api_call_disconnected:
Cause Value=38, Interface=0x3D835BF0, Call Id=21
Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
*Feb 24 13:35:20.803: //20/54E7758E802B/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
*Feb 24 13:35:20.803: //21/54E7758E802B/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=21
*Feb 24 13:35:20.803: //21/54E7758E802B/CCAPI/ccCallDisconnect:
Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
*Feb 24 13:35:20.803: //21/54E7758E802B/CCAPI/cc_api_get_transfer_info:
*Feb 24 13:35:20.803: //21/54E7758E802B/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3D835BF0, Tag=0x0, Call Id=21,
Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
*Feb 24 13:35:20.803: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb 24 13:35:20.803: :cc_free_feature_vsa freeing 3C8A5C00
*Feb 24 13:35:20.803: vsacount in free is 1
*Feb 24 13:35:20.803: //20/54E7758E802B/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=20007, Params=0x2104F160, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Feb 24 13:35:20.803: //20/54E7758E802B/CCAPI/ccCheckClipClir:
Guid=54E7758E-9C8F-11E3-802B-CEBF22E24994, Outgoing Dial-peer=20007
*Feb 24 13:35:20.803: //20/54E7758E802B/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=7139
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
*Feb 24 13:35:20.803: //20/54E7758E802B/CCAPI/ccIFCallSetupRequestPrivate:
*Feb 24 13:35:20.803: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 24 13:35:20.803: :cc_get_feature_vsa malloc success
*Feb 24 13:35:20.803: cc_get_feature_vsa count is 2
*Feb 24 13:35:20.803: :FEATURE_VSA attributes are: feature_name:0,feature_time:1015700488,feature_id:25
*Feb 24 13:35:20.803: //22/54E7758E802B/CCAPI/ccIFCallSetupRequestPrivate:
*Feb 24 13:35:20.803: //22/54E7758E802B/CCAPI/ccCallSetContext:
Context=0x2104F110
*Feb 24 13:35:20.803: //20/54E7758E802B/CCAPI/ccSaveDialpeerTag:
*Feb 24 13:35:20.807: //22/54E7758E802B/CCAPI/cc_api_update_call_info:
Interface=0x234EC5BC, Call Id=0x16
*Feb 24 13:35:20.807: //22/54E7758E802B/CCAPI/cc_api_call_proceeding:
*Feb 24 13:35:20.811: //22/54E7758E802B/CCAPI/cc_api_call_alert:
*Feb 24 13:35:20.811: //20/54E7758E802B/CCAPI/ccCallAlert:
*Feb 24 13:35:20.811: //20/54E7758E802B/CCAPI/ccCallFeature:
Feature Type=25, Call Id=20
phone number 7139 answer the call
*Feb 24 13:35:52.771: //22/54E7758E802B/CCAPI/cc_api_call_connected:
Connection Handle=0
*Feb 24 13:35:52.775: //20/54E7758E802B/CCAPI/ccGenerateToneInfo:
*Feb 24 13:35:52.775: //20/54E7758E802B/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x14, gcid=54E7758E-9C8F11E3-802BCEBF-22E24994, tag=0x0)
*Feb 24 13:35:52.775: //22/54E7758E802B/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x16, gcid=54E7758E-9C8F11E3-802BCEBF-22E24994, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=20, Call Id2=22, Tag=0x0
*Feb 24 13:35:52.775: //20/54E7758E802B/CCAPI/cc_api_bridge_done:
Conference Id=0x6, Source Interface=0x3EA8ABC0, Source Call Id=20,
Destination Call Id=22, Disposition=0x0, Tag=0xFFFFFFFF
*Feb 24 13:35:52.775: //22/54E7758E802B/CCAPI/cc_api_bridge_done:
Conference Id=0x6, Source Interface=0x234EC5BC, Source Call Id=22,
Destination Call Id=20, Disposition=0x0, Tag=0xFFFFFFFF
*Feb 24 13:35:52.775: //20/54E7758E802B/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0x6, Destination Call Id=22)
Call Entry(Conference Id=0x6, Destination Call Id=20)
*Feb 24 13:35:52.775: confID:0x6; callEntry1 callID1:0x14, type:6; callEntry2 callID2:0x16, type:6
*Feb 24 13:35:52.775: //20/54E7758E802B/CCAPI/cc_api_caps_ind:
Destination Interface=0x234EC5BC, Destination Call Id=22, Source Call Id=20,
*Feb 24 13:35:52.775: //22/54E7758E802B/CCAPI/cc_api_caps_ind:
Destination Interface=0x3EA8ABC0, Destination Call Id=20, Source Call Id=22,
*Feb 24 13:35:52.775: //22/54E7758E802B/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=8448)
*Feb 24 13:35:52.775: //20/54E7758E802B/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=2992)
*Feb 24 13:35:52.775: //20/54E7758E802B/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
*Feb 24 13:35:52.775: //20/54E7758E802B/CCAPI/ccCallFeature:
*Feb 24 13:35:52.775: //22/54E7758E802B/CCAPI/cc_api_voice_mode_event:
Call Id=22
Call Entry(Context=0x2104F110)
*Feb 24 13:35:52.779: //20/54E7758E802B/CCAPI/cc_api_voice_mode_event:
Call Id=20
Call Entry(Context=0x2104C820)
*Feb 24 13:35:52.779: //20/54E7758E802B/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x6, Call Id1=20, Call Id2=22
phone number 7139 end the call
*Feb 24 13:36:04.979: //22/54E7758E802B/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x234EC5BC, Call Id=22
*Feb 24 13:36:04.979: //20/54E7758E802B/CCAPI/ccConferenceDestroy:
Conference Id=0x6, Tag=0x0
*Feb 24 13:36:04.979: confID:0x6; callEntry1 callID1:0x14, type:6; callEntry2 callID2:0x16, type:6
*Feb 24 13:36:04.979: //20/54E7758E802B/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=22, Disposition=0x0, Tag=0x0
*Feb 24 13:36:04.979: //22/54E7758E802B/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=20, Disposition=0x0, Tag=0x0
*Feb 24 13:36:04.979: //20/54E7758E802B/CCAPI/cc_generic_bridge_done:
*Feb 24 13:36:04.979: //20/54E7758E802B/CCAPI/ccCallDisconnect:
*Feb 24 13:36:04.979: //20/54E7758E802B/CCAPI/cc_api_get_transfer_info:
*Feb 24 13:36:04.979: //22/54E7758E802B/CCAPI/ccCallDisconnect:
*Feb 24 13:36:04.979: //22/54E7758E802B/CCAPI/cc_api_get_transfer_info:
*Feb 24 13:36:04.983: //22/54E7758E802B/CCAPI/cc_api_call_feature:
Feature Type=6, Interface=0x234EC5BC, Call Id=22
*Feb 24 13:36:04.983: //20/54E7758E802B/CCAPI/cc_api_call_feature:
Feature Type=6, Interface=0x3EA8ABC0, Call Id=20
*Feb 24 13:36:04.983: //22/54E7758E802B/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234EC5BC, Tag=0x0, Call Id=22,
*Feb 24 13:36:04.987: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb 24 13:36:04.987: :cc_free_feature_vsa freeing 3C8A5C00
*Feb 24 13:36:04.987: vsacount in free is 1
*Feb 24 13:36:04.987: //20/54E7758E802B/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3EA8ABC0, Tag=0x0, Call Id=20,
*Feb 24 13:36:04.987: :cc_free_feature_vsa freeing 3C8A5A40
*Feb 24 13:36:04.987: vsacount in free is 0
02-24-2014 06:52 AM
Can you add change this on Gig0/0 as logs shows Disconnect cause=38. And then send accros debug message.
interface GigabitEthernet0/0
h323-gateway voip bind srcaddr 192.168.1.1
02-25-2014 12:19 AM
I put the following command but SNR still not working :
This is the log file with the command dial-peer hunt
phone 1001 call phone 7139
*Feb 25 08:11:24.767: //-1/40CE8A468016/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
*Feb 25 08:11:24.767: //-1/40CE8A468016/CCAPI/cc_api_call_setup_ind_common:
Interface=0x3DFFEA28, Call Info(
*Feb 25 08:11:24.771: //-1/40CE8A468016/CCAPI/ccCheckClipClir:
*Feb 25 08:11:24.771: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 25 08:11:24.771: :cc_get_feature_vsa malloc success
*Feb 25 08:11:24.771: cc_get_feature_vsa count is 1
*Feb 25 08:11:24.771: :FEATURE_VSA attributes are: feature_name:0,feature_time:982236504,feature_id:9
*Feb 25 08:11:24.771: //9/40CE8A468016/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Feb 25 08:11:24.771: //9/40CE8A468016/CCAPI/cc_process_call_setup_ind:
Event=0x231D0DC0
*Feb 25 08:11:24.771: //9/40CE8A468016/CCAPI/ccCallSetContext:
Context=0x2102AE5C
>>>>CCAPI handed cid 9 with tag 20009 to app "_ManagedAppProcess_Default"
*Feb 25 08:11:24.771: //9/40CE8A468016/CCAPI/ccCallSetupAck:
Call Id=9
*Feb 25 08:11:24.771: //9/40CE8A468016/CCAPI/cc_api_set_transfer_info:
*Feb 25 08:11:24.771: //9/40CE8A468016/CCAPI/ccGenerateToneInfo:
Tone Direction=Network, Params=0x0, Call Id=9
*Feb 25 08:11:24.771: //9/40CE8A468016/CCAPI/ccSetDigitTimeouts:
*Feb 25 08:11:24.771: //9/40CE8A468016/CCAPI/ccCallReportDigits:
(callID=0x9, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=9
*Feb 25 08:11:24.771: //9/40CE8A468016/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x3DFFEA28, callID=0x9, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x3DFFEA28, Call Id=9
*Feb 25 08:11:25.195: //9/40CE8A468016/CCAPI/cc_api_call_digit_begin:
Source Call Id=9, Digit=7, DigitBeginFlags=0x0,
Rtp Timestamp=0x61698, Rtp Expiration=0x0
*Feb 25 08:11:25.195: //9/40CE8A468016/CCAPI/cc_api_call_digit_end:
Source Call Id=9, Digit=7, Duration=100,
*Feb 25 08:11:25.399: //9/40CE8A468016/CCAPI/cc_api_call_digit_begin:
Source Call Id=9, Digit=1, DigitBeginFlags=0x0,
Rtp Timestamp=0x69398, Rtp Expiration=0x0
*Feb 25 08:11:25.399: //9/40CE8A468016/CCAPI/cc_api_call_digit_end:
Source Call Id=9, Digit=1, Duration=100,
*Feb 25 08:11:25.595: //9/40CE8A468016/CCAPI/cc_api_call_digit_begin:
Source Call Id=9, Digit=3, DigitBeginFlags=0x0,
Rtp Timestamp=0x71098, Rtp Expiration=0x0
*Feb 25 08:11:25.595: //9/40CE8A468016/CCAPI/cc_api_call_digit_end:
Source Call Id=9, Digit=3, Duration=100,
*Feb 25 08:11:25.795: //9/40CE8A468016/CCAPI/cc_api_call_digit_begin:
Source Call Id=9, Digit=9, DigitBeginFlags=0x0,
Rtp Timestamp=0x78D98, Rtp Expiration=0x0
*Feb 25 08:11:25.795: //9/40CE8A468016/CCAPI/cc_api_call_digit_end:
Source Call Id=9, Digit=9, Duration=100,
*Feb 25 08:11:25.795: //9/40CE8A468016/CCAPI/ccCallReportDigits:
(callID=0x9, digit_event=0x0, enable=FALSE, consume=FALSE)
*Feb 25 08:11:25.795: //9/40CE8A468016/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x3DFFEA28, callID=0x9, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Feb 25 08:11:25.795: //9/40CE8A468016/CCAPI/ccCallProceeding:
*Feb 25 08:11:25.795: //9/40CE8A468016/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=7, Params=0x2102C324, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Feb 25 08:11:25.795: //9/40CE8A468016/CCAPI/ccCheckClipClir:
Guid=40CE8A46-9D2B-11E3-8016-DD176E11F613, Outgoing Dial-peer=7
*Feb 25 08:11:25.799: //9/40CE8A468016/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=7139
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
*Feb 25 08:11:25.799: //9/40CE8A468016/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x22D4E3F0, Interface Type=1, Destination=, Mode=0x0,
*Feb 25 08:11:25.799: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 25 08:11:25.799: :cc_get_feature_vsa malloc success
*Feb 25 08:11:25.799: cc_get_feature_vsa count is 2
*Feb 25 08:11:25.799: :FEATURE_VSA attributes are: feature_name:0,feature_time:982236280,feature_id:10
*Feb 25 08:11:25.799: //10/40CE8A468016/CCAPI/ccIFCallSetupRequestPrivate:
*Feb 25 08:11:25.799: //10/40CE8A468016/CCAPI/ccCallSetContext:
Context=0x2102C2D4
*Feb 25 08:11:25.799: //9/40CE8A468016/CCAPI/ccSaveDialpeerTag:
*Feb 25 08:11:25.799: //10/40CE8A468016/CCAPI/ccGetMediaClassTag:
media class tag 0
*Feb 25 08:11:25.799: //10/40CE8A468016/CCAPI/ccSetMediaclassIp2ipTags:
*Feb 25 08:11:25.799: //9/40CE8A468016/CCAPI/ccSetMediaclassIp2ipTags:
*Feb 25 08:11:25.799: //10/40CE8A468016/CCAPI/ccGet_xc_nr_asp_info:
*Feb 25 08:11:25.799: //9/40CE8A468016/CCAPI/ccGet_xc_nr_asp_info:
*Feb 25 08:11:28.799: //10/40CE8A468016/CCAPI/cc_api_call_disconnected:
Cause Value=38, Interface=0x22D4E3F0, Call Id=10
*Feb 25 08:11:28.799: //9/40CE8A468016/CCAPI/ccCallReleaseResources:
*Feb 25 08:11:28.799: //10/40CE8A468016/CCAPI/ccCallSetAAA_Accounting:
Accounting=1, Call Id=10
*Feb 25 08:11:28.799: //10/40CE8A468016/CCAPI/ccCallDisconnect:
*Feb 25 08:11:28.799: //10/40CE8A468016/CCAPI/cc_api_get_transfer_info:
*Feb 25 08:11:28.799: //10/40CE8A468016/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x22D4E3F0, Tag=0x0, Call Id=10,
*Feb 25 08:11:28.799: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb 25 08:11:28.799: :cc_free_feature_vsa freeing 3A8BBC70
*Feb 25 08:11:28.799: vsacount in free is 1
*Feb 25 08:11:28.799: //9/40CE8A468016/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=20007, Params=0x2102D79C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Feb 25 08:11:28.799: //9/40CE8A468016/CCAPI/ccCheckClipClir:
Guid=40CE8A46-9D2B-11E3-8016-DD176E11F613, Outgoing Dial-peer=20007
*Feb 25 08:11:28.799: //9/40CE8A468016/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=7139
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
*Feb 25 08:11:28.799: //9/40CE8A468016/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x23F092DC, Interface Type=6, Destination=, Mode=0x0,
*Feb 25 08:11:28.799: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 25 08:11:28.799: :cc_get_feature_vsa malloc success
*Feb 25 08:11:28.799: cc_get_feature_vsa count is 2
*Feb 25 08:11:28.799: :FEATURE_VSA attributes are: feature_name:0,feature_time:982236280,feature_id:11
*Feb 25 08:11:28.799: //11/40CE8A468016/CCAPI/ccIFCallSetupRequestPrivate:
*Feb 25 08:11:28.799: //11/40CE8A468016/CCAPI/ccCallSetContext:
Context=0x2102D74C
*Feb 25 08:11:28.799: //9/40CE8A468016/CCAPI/ccSaveDialpeerTag:
*Feb 25 08:11:28.803: //11/40CE8A468016/CCAPI/cc_api_update_call_info:
Interface=0x23F092DC, Call Id=0xB
*Feb 25 08:11:28.803: //11/40CE8A468016/CCAPI/cc_api_call_proceeding:
Interface=0x23F092DC, Progress Indication=NULL(0)
*Feb 25 08:11:28.807: //11/40CE8A468016/CCAPI/cc_api_call_alert:
Interface=0x23F092DC, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
*Feb 25 08:11:28.807: //9/40CE8A468016/CCAPI/ccCallAlert:
*Feb 25 08:11:28.807: //9/40CE8A468016/CCAPI/ccCallFeature:
Feature Type=25, Call Id=9
phone 7139 ring but not the mobile phone
phone 7139 take the call
*Feb 25 08:12:30.303: //11/40CE8A468016/CCAPI/cc_api_call_connected:
Interface=0x23F092DC, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
*Feb 25 08:12:30.303: //9/40CE8A468016/CCAPI/ccGenerateToneInfo:
*Feb 25 08:12:30.303: //9/40CE8A468016/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x9, gcid=40CE8A46-9D2B11E3-8016DD17-6E11F613, tag=0x0)
*Feb 25 08:12:30.303: //11/40CE8A468016/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0xB, gcid=40CE8A46-9D2B11E3-8016DD17-6E11F613, tag=0x0)
Conference Id=0xFFFFFFFF, Call Id1=9, Call Id2=11, Tag=0x0
*Feb 25 08:12:30.307: //9/40CE8A468016/CCAPI/cc_api_bridge_done:
Conference Id=0x1, Source Interface=0x3DFFEA28, Source Call Id=9,
Destination Call Id=11, Disposition=0x0, Tag=0xFFFFFFFF
*Feb 25 08:12:30.307: //11/40CE8A468016/CCAPI/cc_api_bridge_done:
Conference Id=0x1, Source Interface=0x23F092DC, Source Call Id=11,
Destination Call Id=9, Disposition=0x0, Tag=0xFFFFFFFF
*Feb 25 08:12:30.307: //9/40CE8A468016/CCAPI/cc_generic_bridge_done:
*Feb 25 08:12:30.307: //9/40CE8A468016/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1, Destination Call Id=11)
*Feb 25 08:12:30.307: //11/40CE8A468016/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1, Destination Call Id=9)
*Feb 25 08:12:30.307: confID:0x1; callEntry1 callID1:0x9, type:6; callEntry2 callID2:0xB, type:6
*Feb 25 08:12:30.307: //9/40CE8A468016/CCAPI/cc_api_caps_ind:
Destination Interface=0x23F092DC, Destination Call Id=11, Source Call Id=9,
*Feb 25 08:12:30.307: //11/40CE8A468016/CCAPI/cc_api_caps_ind:
Destination Interface=0x3DFFEA28, Destination Call Id=9, Source Call Id=11,
*Feb 25 08:12:30.307: //11/40CE8A468016/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=9657)
*Feb 25 08:12:30.307: //9/40CE8A468016/CCAPI/cc_api_caps_ack:
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5406)
*Feb 25 08:12:30.307: //9/40CE8A468016/CCAPI/ccCallConnect:
*Feb 25 08:12:30.307: //9/40CE8A468016/CCAPI/ccCallFeature:
*Feb 25 08:12:30.307: //11/40CE8A468016/CCAPI/cc_api_voice_mode_event:
Call Id=11
Call Entry(Context=0x2102D74C)
*Feb 25 08:12:30.311: //9/40CE8A468016/CCAPI/cc_api_voice_mode_event:
Call Id=9
Call Entry(Context=0x2102AE5C)
*Feb 25 08:12:30.311: //9/40CE8A468016/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x1, Call Id1=9, Call Id2=11
phone 7139 end call
*Feb 25 08:12:42.955: //11/40CE8A468016/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x23F092DC, Call Id=11
*Feb 25 08:12:42.955: //9/40CE8A468016/CCAPI/ccConferenceDestroy:
Conference Id=0x1, Tag=0x0
*Feb 25 08:12:42.955: confID:0x1; callEntry1 callID1:0x9, type:6; callEntry2 callID2:0xB, type:6
*Feb 25 08:12:42.955: //9/40CE8A468016/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=11, Disposition=0x0, Tag=0x0
*Feb 25 08:12:42.955: //11/40CE8A468016/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=9, Disposition=0x0, Tag=0x0
*Feb 25 08:12:42.955: //9/40CE8A468016/CCAPI/cc_generic_bridge_done:
*Feb 25 08:12:42.955: //9/40CE8A468016/CCAPI/ccCallDisconnect:
*Feb 25 08:12:42.955: //9/40CE8A468016/CCAPI/cc_api_get_transfer_info:
*Feb 25 08:12:42.955: //11/40CE8A468016/CCAPI/ccCallDisconnect:
*Feb 25 08:12:42.955: //11/40CE8A468016/CCAPI/cc_api_get_transfer_info:
*Feb 25 08:12:42.959: //11/40CE8A468016/CCAPI/cc_api_call_feature:
Feature Type=6, Interface=0x23F092DC, Call Id=11
*Feb 25 08:12:42.959: //9/40CE8A468016/CCAPI/cc_api_call_feature:
Feature Type=6, Interface=0x3DFFEA28, Call Id=9
*Feb 25 08:12:42.959: //11/40CE8A468016/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x23F092DC, Tag=0x0, Call Id=11,
*Feb 25 08:12:42.959: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb 25 08:12:42.959: :cc_free_feature_vsa freeing 3A8BBC70
*Feb 25 08:12:42.959: vsacount in free is 1
*Feb 25 08:12:42.963: //9/40CE8A468016/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3DFFEA28, Tag=0x0, Call Id=9,
*Feb 25 08:12:42.963: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb 25 08:12:42.963: :cc_free_feature_vsa freeing 3A8BBD50
*Feb 25 08:12:42.963: vsacount in free is 0
02-24-2014 07:01 AM
Thank you
Do you need the srst mode auto-provision all command? Why not use the none version of this command? Due you need the config present on the router?
02-24-2014 09:30 AM
I only have configured "srst mode auto-provision all" for analog device because I have VG204 or VG224 and I don't need to display the name but only the number when CUCM is not available. So I don't need to configure VG204 or VG224 on the CME-SRST, it will learn automatically the configuration from CUCM and CME-SRST will create all ephone-dn and all phone for analog device when CUCM is not available. On the CUCM all VG204 or VG224 have the setting "remote device" and the good device pool for SRST.
For IP phone of users it is different because we need to display the name when we make a call, we need function like SNR, Call Pickup, Speed Dial BLF, Hunt Group ... so I have to configure all phone manually with all parameters because "srst mode auto-provision all" don't do that automatically. On the CUCM, all IP phone don't have the setting "remote device" but only the good device pool for SRST.
02-25-2014 04:34 AM
With dial-peer hunt enable this is what happening with the call...
---------------First the call matches DP-7 and then it send it to CUCM-----------------
---------With no response from CUCM its matches the second local CME dial-peer ------------------------
-----------Now its stop routing for third try and did not detect SNR config under the DN.------------------
But when dial-peer hunt is disabled , it first route the call to Dial-peer=20007 and then Dial-peer=100.
Now to resolve this we need to stop router to send first try towards CUCM through DP-7.We need to change preference for DP 7 .
dial-peer voice 7 voip
preference 8
If you get fast busy for inbound call , then we need to change CME router config to treat and route inbound call properly.
Rate all helpful post.
Manish
