Community Member
CME SRST version for CallManager
I have an CallManager 4.1(3)sr5b and I want to use an CallManager Express as SRST to provide some sites with more features in fallback mode.
Someone knows, if I can use version 4.0 or what version is more recommended to me?
I look through the CallManager compatibility matrix, and I cannot found this information.
Best Regards.
1 ACCEPTED SOLUTION
Re: CME SRST version for CallManager
Probably you can check the CME compatibility matrix.
This one is for 4.0:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme40spc.html
It's compatible with CCM 4.1.3, so you can use it.
In this link you will find all the CME's compatibility info in case you want to check a later CME version:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_device_support_tables_list.html
Hope this helps! :)
Regards, Tere. If you find this post helpful, please rate! :)
Hope this helps! :)
Hall of Fame Super Red
Hi Fabio,
Just to add a note to the good info from Tere (+5 points for this Tere :)
The four (listed) supported versions for CCM 4.1 are;
SRST 3.4
SRST 4.0
SRST 4.1
SRST 4.2
Check out Table 125 of this excellent doc;
Cisco Unified Communications Manager Software Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp1607786
Hope this helps!
Rob
Community Member
Hi Rob,
I already saw this document, my doubt was if the SRST compatibility and the CME compatibility was the same, once CME have no SRST integration until version 3.4.
Best Regards,
Fabio
218
