CME & SRST
Can CME & SRST be installed on the same router. ( don't think so), If not what's the technical reason for that?
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: CME & SRST
Yes it can.
However it has some restrictions...
Restrictions for SRST Fallback Support
•The call-manager-fallback command, which is used to configure Cisco Unified SRST, cannot be used on a router that is configured for Cisco Unified CME.
•The telephony-service setup command and auto assign command must not be enabled on a Cisco Unified CME router configured for SRST fallback mode. If you used the telephony-service setup command before configuring the router for SRST fallback support, you must remove any unwanted ephone directory numbers created by the setup process.
•The number of phones that fall back to a Cisco Unified CME router in SRST mode cannot exceed the maximum number of phones that is supported by the router. To find the maximum number of phones for a particular router and Cisco Unified CME version, see the appropriate Cisco CME Supported Firmware, Platforms, Memory, and Voice Products document at http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_device_support_tables_list.html.
Hvae a look at this document on how to configure srst fallback with CCME
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesrst.html
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Re: CME & SRST
Yes it can.
Re: CME & SRST
Deji,
Thanks a ton!! One more help, could you please list the major enhancements in CUE 3.1 compared to CUE 2.2?
Ashok
476
