CME SSL VPN with ASA
Hi all,
We're working on a new CME 9.1 deployment for a small office. As part of this deployment, our plan was to have several remote phones connect via SSLVPN to an ASA on our network border which would let them communicate with the CME router. We purchased the appropriate VPN licenses for the ASA and the paper licenses for the remote phones.
I'm following instructions from this document: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmevpn.pdf
However, the trouble I'm having is that when I try to enter the vpn-group settings (page 19 of the pdf) the command is not available on my router - unrecognized command. I fear this might mean I'm missing a license/feature set on my CME router,  is that correct? We purchased a C2921CME-SRSTK9 router but maybe I need the SEC/K9 license? If that is the case, can anyone show me the part number or SKU I would need to purchase?
Alternatively, is there anyway that I could bypass adding this to the router config - maybe modify the phone config XML directly?
Thanks in advance!
Everyone's tags (3)
1 ACCEPTED SOLUTION
Thats correct, you will need
Thats correct, you will need the security license. SKU is: L-SL-29-SEC-K9=
http://www.cisco.com/c/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/data_sheet_c78-556151.html
Please rate useful posts.
1 REPLY
80
