CME switchover incase PRI failover
I have 2 CME each one is having one PRI terminated. I have 20 phones. 10 is registered to CME-1, rest 10 t the 2nd CME-2. I wan to achieve: if PRI-1 goes down, phones registered to CME-1 will get de-register & re-register with CME-2. Is this achievable. I am using CME 8.6.....
Kindly suggest....
Hall of Fame Super Silver
I don't see how you can have phone register with another CME based on PRI being down, but what you can do is simply create another dial-peer that would allow CME-1 phones reach PRI at CME-2 location. Simply create voip dial-peer with higher preference and allow h323-h323 communication.
HTH,
Chris
Re: CME switchover incase PRI failover
Will Any scripting kind of thing help.
202
