Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CME TEHO
Can I get some help on how to get two CME sites to do TEHO with each other. I have an office in Macau and one in Singapore both with CME and they want to do TEHO between the two.
Here is what I have so far:
Macau Router
dial-peer voice 65 voip
description TEHO For Singapore Numbers
preference 1
destination-pattern 900165........
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.75.1
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
no vad
Singapore Router
dial-peer voice 65 pots
port 0/0/0:15
forward-digits 9
prefix 9
dial-peer voice 165 voip
voice-class codec 1
voice-class h323 1
no vad
Not sure which of these to use or if they are even correct....
btw, we don't have a gatekeeper.
Hall of Fame Super Gold
Re: CME TEHO
TEHO, what is that, what is that you want to do ?
Re: CME TEHO
We want to do least cost routing so calls destined for a local number in Singapore that originates in Macau will go across the WAN and out their gateway so it looks like a local call.
Re: CME TEHO
That is more commonly called toll bypass, your example above is Ok except it has many commands not needed, and the numbers and prefixes need to be adjusted specifically.
Re: CME TEHO
So do I need the pots or voip dial peer on the Singapore router for calls from Macau to a local number in Singapore? I'm not sure how the Singapore side receives the voip call from Macau then sends it out its PRI/ISDN line.
Re: CME TEHO
All is defined by dial-peer. You can hire a networking professional for the best results, or study and try yourself:
http://www.cisco.com/en/US/tech/tk652/tk90/tech_tech_notes_list.html
573
