CME termination sign # with dial-peer?
All,
I am wondering if CME POTS dial-peer has '#' sign as its default termination key.
I found in CME VOIP dial-peer, it will recognize '#' as default termination key which stop T302 timeout timing.
ie, I have dial-peer voice 999 voip
destiantion-pattern 25T
when I dial '2550#' in one of ephone, it will ring remote x2500 immediately.
For POTS dial-peer, I cannot confirm '#' sign as default key.
Can anyone confirm for me?
This will affect the dial-peer setup.
1 ACCEPTED SOLUTION
Re: CME termination sign # with dial-peer?
Yes, # is the termination character for POTS dial peers when using T in the destination pattern.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Hope this helps.
Brandon
Hope this helps.
Brandon
Great - good man Brandon.
thanks - also rate for 5.
In summary:
By default both CCM and CME/SRST IOS support '#' sign as termination for timer.
In CCM, it works with wildcard '!' and '@'.
In IOS, it works with 'T'.
James
James,
You are correct. Thanks for the rating.
Brandon
244
