CME TFTP ADDRESS ISSUE
Charlie Mayes
                       Hello All,
                                   I am running CME but and using the CIPC version 7 softphone. When I load the CIPC software on a windows 7 machine the software states it cannot find the default tftp server. Also the CIPC software greyed out so you can not manually change the setting from default tftp server to a manual one. How do you configure your cme router to auto populate the tftp default settings for the cisco soft phone since I can not sethem myself ?
Keith Fulcher
Which version of Windows 7 (32 bit or 64bit)?
Which version of CIPC?
Win 7 and CIPC Support info:
https://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7046/ps7282/product_bulletin_c25-563280_ps1846_Products_Bulletin.html
Win7 32 bit :
Version 7.0.4, FCS Q2CY10
Version 8.5, FCS Q4CY10
Win7 64bit:
WoW64 - Version 7.0.4, FCS Q2CY10
PLZ Rate if you find helpfull.
